Kv rating on SV27 motor??
  • NorthernBoater
    • 811
    Does anyone know what the Kv rating on the SV27 motor is. I could not find any contact info on Aquacrafts webpage.
  • andym
    More Go Than Show Prop Co
    • 2406
    I believe it is just over 1600 kv
    • Steven Vaccaro
      Administrator
      • 8724
      I think its closer to 1800. Aquacraft is tight lipped on the specs.
      Steven Vaccaro
      • Darin Jordan
        • 8332
        I'm 99% certain that these are the specs:
        Stock No.: GPMG5315
        Motor Dia. (mm): 36
        Motor Length (mm): 56
        Shaft Dia. (mm): 5
        Shaft Length (mm): 15
        RPM/V (kV Rating): 1800
        Weight: 10.0 oz. (283 g)
        Suggested Prop Size: 10x7E - 18x10E
        Input Voltage: 14.8-22.2
        Max Constant Current (amps): 50
        Max Constant Watts: 1110
        Max Surge Current (amps): 90
        Max Surge Watts: 2000
        No Load Current (amps): 1.9
        Electrical Connector Size: 4 mm
        I have the specs for their other motors as well... there are 3 in the 56-series motors (36-56); one is 1200KV, one is 1800KV, and the third is 2600KV... The 1800KV one is shown above, and is the one that makes the most sense, given this boats performance and 45-amp ESC...
        Darin E. Jordan - Renton, WA
        • NorthernBoater
          • 811
          Thanks for the info. I did find an email and got a response that no information was available.
          • Steven Vaccaro
            Administrator
            • 8724
            Stock No.: GPMG5315
            Motor Dia. (mm): 36
            Shaft Dia. (mm): 5
            Its the logical assumption. What gets me is why did they use male connectors on the sv motor and female connectors on the ammo motors?
            Steven Vaccaro
              • 7277
              Will the SV motor really handle 22.2 volts ??
              • Steven Vaccaro
                Administrator
                • 8724
                At 22v its about 40k rpm. Most bl motors are good for that or better these days.
                Steven Vaccaro
                • hammertime
                  • 513
                  ill try it...... ill take one for the team.
                  60% of the time... it works every time!
                    • 7277
                    Let me know Please:) how it holds up, I've got 4, 5000Mah 5S's being delivered soon for my V-24 mod and I would love to be able to use them with my Llumar, Blackjack and Super Hawaii as well, after of course , upgrading the speed controllers, I think the Aquacraft ones would die pretty quickly
                    • Steven Vaccaro
                      Administrator
                      • 8724
                      I think the voltage alone would kill the aqua esc.
                      Steven Vaccaro
                      • hammertime
                        • 513
                        i have a different esc.... ill try that motor on 16 cells first and move up..... it will be in the bandit cat
                        • hammertime
                          • 513
                          doby first test will take place tommorow...... vid as well..... im going to make some 8 and 9 cells packs first my esc can only handle 18..... wellll see!!.... i have 3 of these motors so i dont mind fryin one for science lol
                            • 7277
                            Hammer; we all appreciate the sacrifices you are about to make ( hopefully not ) in the name of science:D :D
