SV Brushless System in Titan 29
  • Norman2
    • Sep 2008
    • 354
    Hi, I just installed this and having problems with interference. Once I arm the
    ESC the motor and steering servos will go on wihtout touching the TX. Should
    I use an RX pack and if I do how do I disable the BEC on the SV ESC. Or can I use
    the RX pack without disabling the BEC on the ESC. Thanks as this is my first try at
    brushless.
    Norman2
    34" Ekos Cat UL-1 Powered
  • Jimmy Sterling
    • Apr 2008
    • 417
    Hi Norman,
    Do you have any control of the ESC/Motor or servo ?
    What Radio are you using ?
    Come to the FASST side
    • Norman2
      • Sep 2008
      • 354
      SV Brushless System on Titan 29
      Hi Jimmy, Yes I have control of both but when I let go of the pistol grip and
      move it around the boat the rudder gliches and the motor goes on and off.
      Thanks
      Norman
      PS I use a Futaba FM 2 Channel and it has always worked well
      • Jimmy Sterling
        • Apr 2008
        • 417
        Norman,
        By what you have told me I highly doubt that it has anything to do with the Aqua Craft system,
        Has the reciever ever had water on it ?
        Where is the receiver located in the boat ?
        Jimmy
        • Norman2
          • Sep 2008
          • 354
          SV Brushless
          Hi Jimmy, No it has never been wet. It is located near the transom opposite the
          servo. I will try an RX pack to test. Again thanks for your kind help.
          Norman
          • mtgoat
            • Apr 2008
            • 103
            Originally posted by Norman2 View Post
            Should I use an RX pack and if I do how do I disable the BEC on the SV ESC.
            If you use a Rx pack, disconnect the center (red) wire from the ESC to the Rx. If you don't want to disfigure the ESC, you can buy an inexpensive 6" servo extension and remove the middle wire from that.
            I don't know if that will cure your glitches, but using a Rx pack is a good idea.
            • Norman2
              • Sep 2008
              • 354
              SV Brushless System
              Thanks for your help. Will follow your advice and see if it works with an RX pack.
              Thanks again
              Norman
              • Flying Scotsman
                Fast Electric Adict!
                • Jun 2007
                • 5195
                A RX pack will not solve your problem. It sounds like a frequency/crystal issue
                Douggie
                  What the OP describes is not uncommon with many cheaper radios; if the transmitter is too close to the boat the receiver can buzz the ESC and servos. If the OP moves the transmitter ten feet away from the boat, the problem should stop. If it does not then there is something else wrong.
                  • Norman2
                    • Sep 2008
                    • 354
                    SV Brushless System
                    Thanks again for your help. Followe Mtgoat's advice. Disabled the red lead
                    on a 6" extension. Installed RX pack and the problem is solved. No more
                    glitches, works perfectly. The radio has always worked when I had the 700 SC
                    and Astro flight 212D ESC. Anyway fixed and happy. Thanks to all of you for
                    your inputs. By the way I even got one more minute of run time. Up to 5 1/2
                    minutes.
                    Norman
