I'm not sure how to search the forum but I'm sure it's there. I want to change the outdrive but need some guidance on the hardware needed. I have looked at the fuller stuff but was wondering what other people have done. The offset rudder just looks weird so I was thinking of something in line unless the offset thing is no big deal. I will use the old steerable outdrive on another boat so it's time to make a decision. Thanks for any input, Brian
bj26 outdrive change
Offset rudder is more adapted toward running right turn ovals, left turns are a little harder. A inline rudder will turn equally as well both left and right.
Check here also, they sell a conversion kit, scroll down to find it:
http://www.aeromarinerc.com/runninggear.aspMy prop hasn't been wet in a while.
Also a inline rudder is a pain in the A#$e when you have to regrease your shaft after every run, because the rudder gets in the way. i used a solinger hardware, it is a little different to the fullers but works great.returning to boats after a big break
