Hydro balance
  • m4a1usr
    Fast Electric Addict
    • 2036
    #61
    Originally posted by sporthydrofan View Post
    where is this FE calc...
    Look here. http://forums.offshoreelectrics.com/...ead.php?t=5382
    John
    Change is the one Constant
    • ozzie-crawl
      • Sep 2008
      • 2943
      #62
      you really need 4s on 5s its pulling huge amps which is killing your esc,s
      even if you get a esc to handle the amps your killing your motor it pulling way to many watts
      if you kill the motor while running it there is a chance you will kill the esc as well.
      • sporthydrofan
        • Mar 2010
        • 73
        #63
        yep just dl the FE Calc program very nice indeed!
        looks like the 580L would run very nice with the y537/3 prop and pull less amps
        580L 2154KV
        5S1P- 5 amp
        36k rpm
        95.6 amps
        3 min run time
        est. speed 65 mph
        91% efficiency
        looks like i only have to keep 145 watts cool!
        looks much better than the x640 prop which runs much higher amps and less efficiency
        • sporthydrofan
          • Mar 2010
          • 73
          #64
          ok the FE calc says 95 amps.... but when i put on the amp logger it runs 130 amps with this setup.... does FE have a section to input the size or weight of the boat?
          • Flying Scotsman
            Fast Electric Adict!
            • Jun 2007
            • 5195
            #65
            You need to run 4S max and buy an Esc rated for 180amps minimum with that motor. You have gone through 3 esc's so far as they were not up to the demands you subjected them to. How long do you want to run, as your setup is SAW presently.
            Edit
            Show us a print of your total run with your data logger
            Edit
            FE calc is only an estimate at best
            Douggie
            • sporthydrofan
              • Mar 2010
              • 73
              #66
              So FE is wrong?
              I only blew 2 ESC's so far prop was wrong, the other ESC is fine right now it doesn't even get hot 110 Degrees F, the batteries last about 4 minutes.. im just wondering why the FE calc says 95.6amps and i got 130+ on the logger and the boat only ran 52 mph not the estimated 65mph... the motor specs says it handles up to 8S...
              • ozzie-crawl
                • Sep 2008
                • 2943
                #67
                when they say the 580 is good for 8s its they also give you a 50,000 rpm limit
                which you dont want to go near.but if you ran a 6l on 8s your up around 64,000 rpm. to run 8s you would want a kv that will get you around 30,000
                fe calc wont give you exact numbers and a lot depends on your setup
                if setup wrong you will pull more amps etc.
                the 130 amps your seeing are probably spikes not what your pulling constantly
                under load
                • Flying Scotsman
                  • Jun 2007
                  • 5195
                  #68
                  A 580 8L or 9L may be better suited for 5S or 4S....lower amps and higher torque. It all depends on your run time and desired speed
                  Douggie
                  • sporthydrofan
                    • Mar 2010
                    • 73
                    #69
                    so going to a smaller prop wont help? i just don't have any 4Slipos.. and i have 2 brand new 5S's . it runs great now. but i was just worried about the 130 amp reading. Does FE Calc take into consideration the weight or size of the boat? does it matter?
                    • Flying Scotsman
                      • Jun 2007
                      • 5195
                      #70
                      If you have two 5S, I would change the motor dependant on what you paid for the batteries. 25,000 to 29,000 rpm will give you a fast boat but not SAW speeds. Saw run times are about one minute and very hard on the wallet and equipment.
                      Douggie
                      • sporthydrofan
                        • Mar 2010
                        • 73
                        #71
                        i'm getting about 4 minutes of run time, i don't want saw setup i want a fast sport boat so 3-4 minutes is cool for me
                        • Jeepers
                          • May 2007
                          • 2050
                          #72
                          Douggie
                          I run upwards of 36,000 rpm in my N2 sport hydro I have no problem with heat or burning up equipment just have to prop accordingly, and the boat is FAST!
                          • sporthydrofan
                            • Mar 2010
                            • 73
                            #73
                            ok so look at my setup from FE Calc should i go lower in prop size? say a y536?
                            • Jeepers
                              • May 2007
                              • 2050
                              #74
                              thats what I recommended to you in a few posts back that and an x437! That y537 3 blade you used was.... ok but you add massive load with the extra blade. especially at that rpm your turning.
                              So far all the 3 blade props I have tested I have not been happy with them.
                              • sporthydrofan
                                • Mar 2010
                                • 73
                                #75
                                I just bought a Y536 it seems to give the most speed with the least amp load, it runs 50's now im very happy thanks guys!
