JB weld or Epoxy
  • NorthernBoater
    • 869
    JB weld or Epoxy
    Which is stronger JB weld or 30 minute cure epoxy? What is the best use for each? I am going to be using it to glue the mount to the boat for the motor. There is both wood and metal
  • saleens7
    • 1130
    JB weld....
    saleens7, the wookie of rc boating
    • Mich. Maniac
      • 1456
      If it were glass hull I would go get a little glass matt and resin and glass it in if possible. you would be adding structure as well as making one strong motor mount. and I would almost think doing that you could get the mount out easier if you ever had to for some reason.
      • ReddyWatts
        • 1756
        motor mount
        I like to epoxy and fiberglass in a thin board with three taper head 6/32's sticking up through it. This way if I want to change the motor type or add a trans, I just bolt in a different mount.
        ReddyWatts fleet photo
