CC bec configuration
  • Jesse J
    scale FE enthusiast
    • 7241
    So I finally got me a CC bec. Opening it up, I realized that it needs to be wired to the battery lead? How does one wire this up so it can be swapped between boats? Maybe y-adapter into the ESC with battery? that is bec + battery into ESC in parallel?
    How do you guys wire these for best swappability?
    "Look good doin' it"
    See the fleet
  • D. Newland
    • Dec 2007
    • 1030
    Not my idea, but I plug mine into the balance tap of a lipo. I haven't run it yet, but it seems like it would work just fine.
    • line6
      • 478
      I would just put 2-3 inches of wire of the positive and negative wires coming of your esc. and put some small female bullets on each (so u can cap them if you want) and some male bullets on the bec
      as long as your under 25 volt this will work. almost forgot that
      • bonewar
        • 549
        Cc bec wiring diagram
        Here you go Jesse J .
        • Jesse J
          scale FE enthusiast
          • 7241
          Thanks Bonewar (was wondering how you came up with that name...). I won't be running more than 6S, so I think I will get away with something that comes off the ESC, like Line6 mentioned earlier. That diagram is helpful, but I don't think I will be using 12S for quite a while. I think I will go with small bullets coming off the ESC.
          Has anybody else heard of using the balancing plug for this BEC config?
          See the fleet
          • bonewar
            • 549
            Jesse J The bullet connectors are the go , The pic in my last post was to show you a different method/ This can be used with any cell up to 12. Here is another method (pic) Put the bullet connectors just after the bec. My nick name has always been bone, When i was a young fellow i was always fighting so my mother use to say to me bone at war , hence the name BONEWAR.
            • Jesse J
              scale FE enthusiast
              • 7241
              right on Bonewar, thanks for the bkg and added pic. uhh. . . the leads into the rx are using both channels? where does rudder go? I need to get it out, solder on some leads and figger it out on the bench.
              See the fleet
              • bonewar
                • 549
                Jesse J The bec goes into the batt channel/aux on the RX , 1 channel for esc ,1 channel for rudder. Bonewar
