How to keep my miss Geico 36 twin from porpoising
  • Doctorplumb
    • Oct 2023
    • 8
    How do I keep my Miss Geico 36 twin from porpoising. I have put the batteries as far forward as I can does not help tried weight back does not help, gone as far as 3? negative on the struts does not help went positive on the struts does not help profiled and flattened The bottom did not help.
    HELP Thanks Mark
  • koen
    • Mar 2020
    • 367
    try different props and go back to stock setup
    • Doctorplumb
      • Oct 2023
      • 8
      I think I have tried a few props, thanks for the help. I?ll try some more
      • larryrose11
        • Jun 2010
        • 768
        I have found that the strut length made all the difference in a mono i was running when it was proposing
        Sent from my SM-G990U1 using Tapatalk
          • 4338
          Drive angle and weight distribution can be pretty finicky on exact placement, but many people have been able to find an acceptable balance, so it can be done. With that said, you'd want to look at the bottom of the hull next, and the last two sets of ride pads in particular. Does the hull sit flat when placed on a perfectly true surface like a stone countertop, or will it rock side to side? If you place a straight edge across each of the two ride rear ride pads on each side, are the surfaces true or are they sunken, creating pockets? That can cause bouncing. You may need to sand any high spots, and fill any low spots to get a perfectly flat ride surface. Finally, check the height on the drives and make sure they're both installed at the same level on the rear of the sponsons.
          • Doctorplumb
            • Oct 2023
            • 8
            Thank you so much. I will give it a try.
            • Doctorplumb
              • Oct 2023
              • 8
              Thanks
              Sounds like a good idea
              • 1coopgt
                • Feb 2019
                • 417
                You can't change the length of the struts on the Geico 36. They are already longer than the struts on the Zelos 36 which the Geico 36 is based off of.
                Op when you adjusted the strut heights did you use a gauge so that they were exactly the same height or did you do it by eye with a ruler? I made an aluminum gauge so that I could make sure they were even.
                • Bande1
                  • Mar 2023
                  • 678
                  the boat is teetering around the center of gravity. First thing to do is set the strut to neutral then set the CG to 30%. Run the boat to check if it is better. If not try 32% CG.
                  the lower you run the strut on a cat the faster the boat goes but more lose it runs. you want it level with the sponsons ride pad. start with a 90 degree angle and play with a little positive angle.
                  • 1coopgt
                    • Feb 2019
                    • 417
                    Positive angle is fast and loose . Negative angle is slower = Wet . Forces the front of the boat down.
                    Even though the pic is of a mono hull it still works the same on Cats and Hydros.
                      • 4338
                      Fixed height drives on the Geico twin, can't adjust height, only trim angle.
