I received my Octura flex cable and prop shaft today and curious which is the better way to join these together. On the Offshore Electrics website under the how to they recomend glueing the flex shaft into the prop shaft and the instructions that come with the flex cable say solder. I'll be running a 550 motor. Should I glue it or solder it? If glueing it would JB Weld work as well as the Locktite? Opinions welcome.
Offshore sell this cable and shaft already joined so I'm assumeing they used the glued method
Thank you in advance
