Rsx 310
  • Troy1957
    • Jun 2022
    • 28
    Rsx 310
    Point me in the right direction. RSX 310 SSS 4082 2400kv hydra X on 4S help me with a prop size thinking 42 mm range not sure ?????
  • Bande1
    • Mar 2023
    • 678
    go to the prop calculator and punch in the parameters and figure out a reasonable speed expectation. say 60mph. and find a prop that will give you that.
    ose brass 4216 and adjust the timing to suit your expected runtimes/heat.
    • Peter A
      • 1622
      My GP310 gps at 99kph with a DR Props Nampba 642/3. Depending on water conditions and X445 or 447.
      • khaldrogo
        • Aug 2024
        • 1
        For an RSX 310 SSS 4082 2400KV motor with a Hydra X ESC on a 4S setup, a 42mm prop size sounds like a good starting point. However, the ideal prop size can vary based on the specific setup and the type of boat. You may want to start with a 42mm two-blade prop and monitor the motor and ESC temperatures closely. my perfect hotel
