Help: Removing ESC - TFL Pursuit Carbon ARTR
  • Doubledog
    • Dec 2023
    • 28
    Just took delivery of my new TFL Pursuit (thanks OSE) and want to change out the ESC connectors to bullet style. How in the heck do you remove it from the mount? I see four tiny screws and tried to remove one to no avail.
    Help.
    Thanks!
    Jr.
  • LibertyMKiii
    • Dec 2018
    • 126
    I don't own one of these, but are the tiny screws the ones on the top of the ESC cooling fins you are talking about? Those won't be what is holding the ESC down. Those are just for the heat exchanger.
    Usually these have 3m double sided tape holding them down. Maybe take a piece of floss and see if you can pull it under the esc to break the tape loose. Sometimes a little leverage on the corner from a flat head or pry bar gets it moving. (assuming its taped down)
    • Doubledog
      • Dec 2023
      • 28
      Yep, got the answer on another group and the post above was correct. Double sided tape was holding it like cement almost.
      Thanks and can't wait to run it tomorrow after changing out the connectors and mounting the steering servo.
        • 4340
        You can strap it back down to the mount with velcro straps using the slots in the top of the mount if you want it to be a little more serviceable in the future.
