DF 34 hydro hardware
  • Curtisjames9
    • Nov 2023
    • 17
    Hey fellas -
    My ul19 hull was recently destroyed by my esc. Since these are discontinued, I was eyeing a df34 hydro as a replacement.
    Question - would my ul19 hardware (strut, rudder, fin…) work on the df34 hull? Also, for those of you with this hull, what length are you using for the flex cable? Does the hull need an additional sheet laid in for strength? I don’t plan on going much over 60mph, I just want something reliable and robust.
    thanks!
  • Panther6834
    • Apr 2020
    • 708
    Just curious...but, how much of the UL-19 was destroyed. Reason I'm asking is, while the UL-19, itself, is no longer available, the hull & canopy are still available. HH has the hull on backorder, but other sources (search, and you will find) have them. I'm not saying it's the 'best' solution...but, it's also not the 'worst'. At minimum, rebuilding your UL-19 could be worth considering.
    Sent from my SM-S928U using Tapatalk
    • Curtisjames9
      • Nov 2023
      • 17
      If you’ve found someone with a hull currently in stock - do tell!
      I’ve been unable to find any. I know they are on back order, I just foresee part support getting tougher as time goes on with a discontinued boat.
      it’s a substantial split. All the way across the front, around and down both sides of sponsons.
      • koen
        • Mar 2020
        • 367
        it's not easy but it can be done you can repair the hull ,if you are not familiar with epoxy you can find all the info on the net (west systems is one of the best and have a lot of info on there site)
        • properchopper
          rcgoatbuild@snotmail.com
          • 7708
          Hello Curt,
          The DF34 is to the UL19 like a Dodge Diesel Dually is to a Prius. The UL19 hardware would probably work somewhat for a few runs BUT keep in mind that the DF34 is HEAVY (and exerts lots of centrifugal energy in the turns) and needs strong hardware. With that in mind my build used the way bigger/stronger Speedmaster .60/.90 hardware on back and a modified gas boat turn fin. Do it HD now or rebuild it later
          https://forums.offshoreelectrics.com...ghlight=vortex
            Find someone to build you the new bla2er whiplash.
            • Curtisjames9
              • Nov 2023
              • 17
              While waiting for a replacement hull to show up, I finished repairing the one that split…
              pretty easy to do a carbon inlay with everything wide open! Laid the top and bottom- added weight in the tips, lost the canard, and added a xlx2 - and found a newfound respect for prepping/painting!
              • Curtisjames9
                • Nov 2023
                • 17
                figured everything looks faster in red!
