Prop splash
  • Ivan Kozyakov
    • Apr 2022
    • 113
    Prop splash
    Hi guys!
    Sometimes I hear from experienced racers that the efficiency of a prop can be determined by the spray. Please explain how this works.
    What should you pay attention to?
    The shape of the roostertail can tell a lot about prop performance. A low, flat ‘tail indicates a narrow, efficient thrust cone while a high one indicates a wide thrust cone. The latter is usually seen from high lift props used to raise the aft of the boat.
    • vvviivvv
      • 1148
      Here is a comparisson of Abc vs Octura, not perfect as one is a 1.85m boat and the other 1.5m but you can really see how high the Octura throws the spray, the green one in sport setup is a 100mph boat.
      Abc on my Hpr150
      Octura X470 cut down on my Hpr185
      Uk SAW record holder
      • Ivan Kozyakov
        • Apr 2022
        • 113
        A little confused. Chopper prop shapes produce high splashes, while cleaver shapes props flatter, low sprays?
        Does high splash always mean an ineffective propeller?
        • dasboata
          • Dec 2010
          • 3972
          Iv had my best speeds with gas cats & monos,,with big props run hi, on the transom , with a large spray , I run large pitch with much slip
          • Gary
            • Jan 2009
            • 1104
            Here is an old video where my boat was only running 92mph in this run but you can clearly see a pretty big water spray for that speed.
            It is the same now as well but runs faster at 108 mph. I still feel a more narrow spray could give me more speed but need the transom way out of the water to prevent blow overs. Less spray more bite ???
            H&M 1/8 Miss Bud 73 mph
            Chris Craft 16 mph
