Anyone making 8mm parallel adapters?
  • zooma
    Local club FE racer
    • May 2014
    • 652
    In the past, I've made a "Y" with several inches of 8ga wire. But I'd like to make a block, for neatness and shorter length. Would appreciate seeing some examples.
    Ron - The Villages, FL
  • pescador
    • 499
    I?ve made a few by pinning together the three bullets with copper rod and soldering it all together. I insulated it with a moldable silicone putty that hardens but I forget the name. It came in different colors in small packs like ketchup.
    Namba District 16
    1/8 Miss U.S., 1/8 59 Maverick, 1/8 Executone, 1/8 Smokin Joes, MLGSX380, AC Pro40II Q Sport, AC Pro40II nitro,Twincraft mono 10s, Vision AOPC, VS1 FE, M34.
      • 9438
      I cut copper bar on the lathe. holes are for wire leads and cap pack.
      • Rlimits
        • Jan 2019
        • 82
        • NativePaul
          Greased Weasel
          • 2764
          Is the silicone putty Sugru?
          • properchopper
            rcgoatbuild@snotmail.com
            • 6958
            Food for thought
            • zooma
              Local club FE racer
              • May 2014
              • 652
              Thanks, guys. Now I am leaning toward a "T" configuration. Wonder if "liquid electrical tape" would hold up to the heat.
              • zooma
                Local club FE racer
                • May 2014
                • 652
                Food for thought
                [ATTACH=CONFIG]179051[/ATTACH]
                Thanks. Would have liked to see what's under the heatshrink.
                BTW, Tony, I still run the Hot Stuff crackerbox occasionally. Real crowd pleaser.
                • properchopper
                  • 6958
                  Ron, the harness was basically made with 12 guage wire and lots of soldering. Drop in the batteries for 4S 2P and go. Simple clean plug n' play -El Neato.
                  Glad you're still digging the cracker; my Jersey Skiff sits lonely and dusty.
                  • pescador
                    • 499
                    Yes that was it
                    Namba District 16
                    • Rlimits
                      • Jan 2019
                      • 82
                      • zooma
                        Local club FE racer
                        • May 2014
                        • 652
                        Originally posted by Rlimits View Post
                        [ATTACH=CONFIG]179082[/ATTACH][ATTACH=CONFIG]179083[/ATTACH]
                        Thanks
