Water sucking tube from prop
  • Ivan Kozyakov
    • Apr 2022
    • 113
    Hi guys!
    How does work such a tube with cooling intake from a prop ? Does it suck up only splashes? How effective is it?
    I don't have enough cooling on my hydro boat Dr Super-Evil and I'm thinking of using this option. The water intake from the rudder is not enough, and the intake from the bottom is difficult to implement due to the design of the hull.
  • RaceMechaniX
    • 3024
    These prop blast pickups can be effective so long as they are properly placed in the prop rooster tail. Usually I am not a fan of these for FE boats as the spray can be inconsistent compared to a rudder pickup.
    Tyler Garrard
    NAMBA 639/IMPBA 20525
    T-Hydro @ 142.94mph former WR
    • dasboata
      • Dec 2010
      • 3972
      Originally posted by Ivan Kozyakov View Post
      Hi guys!
      [ATTACH=CONFIG]178927[/ATTACH]
      it's a prop wash pick up should be placed at 2 PM to catch the spray off the prop , on a left rotating prop ,,the only good thing about them is if you run nitro or gas and you run the boat up on the beach and the azz is in the water it might save your engine , , use threw hulls or rudder pick up for best reliability
      • Ivan Kozyakov
        • Apr 2022
        • 113
        Thanks for your advice, I'll give up on this solution. I will try to take water from the bottom.
