lipo battery wires
  • tjsb
    • Mar 2023
    • 492
    lipo battery wires
    How do I replace the wires on a lipo battery the gun I have isn't melting the solder?
    • 4340
    You need a soldering iron with more heat capacity, possibly even a broader tip too. Something that can reach 750C. I use a Hakko FX888 adjustable solder station
    • tjsb
      • Mar 2023
      • 492
      thanks I was told I need flux for aluminum?
      • photohoward1
        • 1781
        Yes
        • NativePaul
          Greased Weasel
          • 2770
          I'm not familiar with farenheit, but is it possible that you meant 750f fweasel? I use 450c and that works fine, you just need a high wattage iron and/or a tip with a lot of thermal mass.
          You need flux for any soldering, but I use flux core solder rather the separate flux for electrical soldering, it is however specialist solder for aluminium rather than the usual 63/37.
            • 4340
            Ah, my mistake, yes I meant 750F
            • jkflow
              • Aug 2021
              • 329
              Careful soldering lipos though, can be done but do not apply heat for longer periods, 5s is the comfort level. Lipos do not like heat and die plus if you melt anything by accident they might catch fire.
              Do it in a fire-safe environment. It can be done and it's safe if done right.
