Looking at ordering an MHZ Mystic 114 likely the pre-assembled kit which is on sale. Is the standard GFK enough? Is the C-AFK or CFK worth the extra cost?
Open to recommendations, thank you all.
GfK for about 120kph crash resistance.
But I can tell from experience that you better buy a cfk ,it's worth it if you crash your paint job stays on and your hull is still in one piece.
I did the carbon and cfk inlay after a crash.
So better spend a bit more money.
Be wary of the MHZ build quality. I heard they're not built like they used to be. I took the chance, and mine was not built like they used to be. My build shows some of the what has been coined "shoddyness".
Easier to get the carbon inlay done now and have the stronger hull instead of realizing you needed it later.
I have seen some pretty bad install work from MHZ on the prebuilt hulls. I suggest you build it yourself, or, set your expectations low.
Are you referring to their pre-assembled 114? That’s the option I was looking at. Damn all these comments have me second guessing. I might as well get a damn Zonda.
There is another alternative to the 114, the Kulz exocet 125 would be my money in this size range if looking for a new hull.
There are some undrilled GFK hulls with rudder and a few other bits included for 300 euro around in Germany....
Even a GFK with a carbon kevlar inlay that looks very good for 300 euro.
How can you even source a hull from Kulz? I can only find his Facebook group. I’m a perfectionist so it sounds like an MHZ is hit or miss and will possibly get me triggered
I've bought a Excoet 150 from him in the past and the hull was very good quality. There's also a gent in TX that has imported 10+ of his hulls that might have one for sale i know he has a bunch of the mono's but im unsure about any cats.
Uk SAW record holder
How can you even source a hull from Kulz? I can only find his Facebook group. I?m a perfectionist so it sounds like an MHZ is hit or miss and will possibly get me triggered 😂
Not being a Facebook member, I hate Facebook shops with links that don't work, and no way of contacting them, unless you join Facebook. like Model Boat Pirate. Wish I could browse his goods.
You can't browse the MBP website because Joe closed the business last year.
Manfred Kulz is not a business, he's a retired guy that does great composite layup work. I've only ever contacted and done business with him via facebook messenger.
