Mono listing to one side
  • BlakeT
    • Jan 2020
    • 536
    I have an aeromarine Titan 29 that is giving me issues leaning hard to one side while I?m on the throttle Or even half throttle. This boat has a 3650 1500kv motor on 6s I run 2 3s 5000mah packs on each side of the motor. I had first started out with an m445 prop which went 51mph but on its side. I then dropped the prop size down to a 440/3 to see if it was torque rolling on me but no change. The strut is about 3/8 up from the bottom so the prop is not very deep in the water. Trim tabs are neutral and turn fins are strait and on the smaller side. I have 2 other Titan 29s running 4s and similar speeds with similar or bigger props with no issues. I have only seen this one other time with a friends 53 inch delta mono doing the same exact thing.
    • 4340
    Sounds like weight distribution isn't an issue. Is CoG similar between your 4S and 6S setups? I assume it's laying down on the starboard side? Is it torque steering also? Any chance there's a hook in the ride pad on the bottom of the hull? I had to offset the strut (from the keel) on a hull I couldn't get to run true.
    • Panchothedog
      • Oct 2015
      • 173
      Lower the trim tab on the side that it is leaning on. It should help. I agree with the post above, I think it's a bottom issue. You might have to do some filling and then sand flat.
      • BlakeT
        • Jan 2020
        • 536
        Yes it is on the starboard side. I’m running CG a little bit further forward on this one since it is a little bit faster and more powerful than the others. No torque steering with the small or big prop. This hull doesn’t have a ride pad like a delta force does it is just a standard keel V shape but I will check it to see if it has any hook.
        • BlakeT
          • Jan 2020
          • 536
          Ok so I just checked both boats (I bought the 53 delta from my friend). The Titan has a small lump of epoxy on the bottom of the keel on the opposing side from which it is leaning. I am going to sand this down and see if it changes anything. The big 53 delta the bottom seems pretty strait however there is a dual water pickup that is through the hull and it is on the starboard side as well.
            • 4340
            You're welcome. Now sell me the Epic.
            • BlakeT
              • Jan 2020
              • 536
              Haha it’s just hanging out ready for a box.
              • BlakeT
                • Jan 2020
                • 536
                I actually just got some batteries the other day adequate enough to drive it.
                • john finch
                  • Mar 2013
                  • 7
                  You might check where the strut is mounted. If the driveshaft comes out the transom just a bit to left of centerline it will cause the issue you have.
