Pathfinder spinning out
  • tjsb
    • Mar 2023
    • 478
    Can anyone show me a setup,prop,ETC for there delta force pathfinder?
    Tom
    • 4340
    Without knowing anything about your setup or hardware being used, I would suggest you start by dialing back the travel on your steering servo
    • Bande1
      • Mar 2023
      • 678
      also 32% center of gravity to start
      • tjsb
        • Mar 2023
        • 478
        Did the servo,as Im turning it will hook if I dont straighten it out half way into the turn.
          • 4340
          Again, since you've provided us with nothing to go on but the fiberglass carrying case in play, my next guess would be a weak servo, sloppy steering linkage, or too much friction in the steering linkage.
          • koen
            • Mar 2020
            • 367
            use a 20kg servo and the boat wil stir
            • tjsb
              • Mar 2023
              • 478
              I have one in it and turning down steering helped
                How wide is the rudder?
                • tjsb
                  • Mar 2023
                  • 478
                  1 x 4 long
                    O.k. the rudder is fine. Too wide and it can cause issues.
                    You could try a skeg strut from OSE.
                    • tjsb
                      • Mar 2023
                      • 478
                      Didnt think of that.
                      Thanks
                      • Xrayted
                        • Jan 2023
                        • 273
                        Unfortunately the CAT hulls are made to go forward well, and that's about it. They are not great at going around a turn at speed as they will easily hook and flip. Some designs are worse than others depending on how wide they are.
                        Narrower hulls will hook and roll easier than a wider boat will. I have a twin myself, and its the one boat that I'm guaranteed to flip at least once at every outing unless I slow down to turn while using as little rudder as possible. I think of CATS like a car that is set up for drag racing but someone trying to run it on a Nascar track instead. It ill scream in the straights, but getting it to turn at speed without ending up on its roof will be a problem
                        • tjsb
                          • Mar 2023
                          • 478
                          LOL I have 3 a Veles that rolls easy runs best with a 4519,pathfinder not a bad again best with a 4519 ,and a Cheetah best with a 4819 that I love it turns on a dime at full speed but not as fast given its size.Veles has a 6s 2200 kv Pathfinder on 5 s with a 2650 kv Cheetah 1900 kv 6s or 7s
                          • Xrayted
                            • Jan 2023
                            • 273
                            Yep, mine is a Miss Geico Twin 6S 2000kv, so essentially the Velos, and its a handful in a corner. I haven't yet tried to swap the cables around and reverse the rotation of the twin pops to rotate outward instead of inward, as that can "sometimes" help to calm a twin cat down a bit in the corners
                              The bolded is not really true. The Veles handles corners well as do numerous cat hulls from the Veles up to 35CC gas boats. The Pathfinder the OP is asking about has almost the same bottom as a Mean Machine.
                              Pathfinder 28 hulls were being used for P Limited cat class up to a year ago when speeds kinda went nut for that class. Because the speeds increased so much people had to seek out hulls with a little better stability in the straughts as well as in corners.
