Cracked BJ 42 Hull- What replacement hull?
  • paDDY
    • Aug 2014
    • 127
    First, I really like the way this blackjack looks and runs. I did a prop change and she fly's well over 70 mph. The problem is the plastic hull can't take it. I have two choices, buy another bj hull and try and reinforce it, (but have a feeling it will eventually fail). Another option is to replace the hull with a fiberglass hull and move the electronics over. Has anyone had luck reinforcing the hull and the boat lasting? Any recommendations for a cat that I can move the electronics over to. 4685 1350 kv motor, I have a few esc that can run 8s.
  • Bande1
    • Mar 2023
    • 678
    pffft thats nothing. fix the hull. reinforce it with some fiberglass or carbon fiber.
    • koen
      • Mar 2020
      • 367
      check the site from OSE a Bandit M hull is perfect for your electronics ,and with a good setup very fast
      • paDDY
        • Aug 2014
        • 127
        I’m going to patch it again, but it just seems to be never ending.
        • paDDY
          • Aug 2014
          • 127
          That looks very nice. Do you think it will do ovals ok?
          • Bande1
            • Mar 2023
            • 678
            fiberglass really isnt much different. if youre crashing a lot they will need constant fixing also.
              • 4340
              ABS hulls tend to be brittle, and the interior surface is difficult to get a quality adhesion to use traditional reinforcement methods, in my experience. You're polishing a turd, as the expression goes.
              • paDDY
                • Aug 2014
                • 127
                lol! Love this! I almost spit my drink. I’m going to patch her up just to run till ose maybe gets a cheeta in the next two months. I might start breaking out the duck tape till she’s totally done.
                  Tony at Promise hobby is pumping out hulls again. He has a decent 42" cat.
                  • paDDY
                    • Aug 2014
                    • 127
                    I just checked his ebay, the Falcon 41" cat looks very promising. It looks like its wider and might do ovals ok?
                    • Bande1
                      • Mar 2023
                      • 678
                      there's this store. never bought from him.
                      https://www.ebay.com/itm/28542350900...=&toolid=10050
                      I can also get you a slightly blemished brand new blazer marine whiplash GV hull for $350. the blemish is in the mold lines being slightly visible requiring bondo work to be seamless, which has already been done at the factory. they are large gas hydro hulls 44" long you can convert to electric. basically its a bare hull with 5" wide wood runners. OSE sells motor mounts for 5" gas rails.
                      https://www.offshoreelectrics.com/pr...prod=ose-83401
                      whiplash GV
                      • Alex.v.Schie
                        • Aug 2020
                        • 35
                        DY motorshop has decent hulls .
                        Only carbon and carbon kevlar hulls are mostly up to hard crashes.
                        But then only the German bullet proof carbon and carbon kevlar hulls are bullet proof.
                        Verstuurd vanaf mijn CPH2409 met Tapatalk
                        • paDDY
                          • Aug 2014
                          • 127
                          whiplash GV
                          https://www.blazermarine.com/index.p...uct_detail&p=4
                          Thanks for the offer on the blazer hull. I really like the cats where I run as it's always choppy in the afternoon. I think the Falcon 41 will be the replacement boat for the blackjack electronics. I'm going to patch the boat up and run it Monday, but it's on limited time. The plastic just can't take the 70+ mph crashes.
                          • paDDY
                            • Aug 2014
                            • 127
                            I think I will end up trying the carbon Falcon 41" once I completely destroy this BJ. I just purchased a bullet proof RM 145 or Bulgarian 57 as ose calls it. It just got delivered to the builder yesterday. But that's months away till I get that in my hands. IMG_9684.jpg
                            • Alex.v.Schie
                              • Aug 2020
                              • 35
                              Very nice ,but then you will need much more power for the bulgarencat [emoji28]
