sss vs leopard motors
  • Bande1
    • Mar 2023
    • 678
    Originally posted by Panther6834 View Post
    I highly doubt the battery voltage/prop size thing you mention...you had to have either misunderstood, is you got that from someone else who misunderstood. Same goes for your final point...what you state there doesn't make any sense, even to someone with almost no knowledge. As for your first point, all I can say is, if that's what worked for him, them that's what worked for him...and, since you provided no info on the boat, itself, it IS possible.
    As for motors brands, having spoken with numerous others, I personally know MANY of them have tested different motors, and can confirm that, of the three (SSS, Leopard, & TP), TP has consistently proven to be the best in "real world" use (ie. not 'specs', which can be fill of lies, thus completely meaningless)...especially the upper-tier motors. The reason most tend to go with SSS & Leopard is that, for the most part, they cost less. From my own personal experience, both brands are still very good (SSS is actually made by TFL)...I trust both in my recreational boats, and have used both in one of my three race boats (that boat is currently running an SSS). I will mention that, in that particular boat, I didn't like the Leopard, which is why I returned it back to SSS.
    Regarding 'specs', for the most part, ALL companies lie to some degree. It doesn't matter if you're taking motors, ESCs, batteries, servos, etc...the numbers they publish are NEVER 100% 'truth'. As someone already mentioned, published numbers tend to be a "marketing gimmick". Additionally, 'numbers' published tend to be from testing done under "perfectly ideal" considering, not "real world" conditions...in the "real world", nothing is ever "perfectly ideal". Plus, since no two units are completely identical, you could test 10 of the exact same motor, servo, etc, and get up to 10 different results.
    We live in an imperfect world...so, you should expect everything in life to be 'imperfect'.
    ~ More peace, love, laughter, & kindness would make the world a MUCH better place
    at IMPBA district race yesterday we talked with the points champ. He told us he quit using TP because he burned them up and uses SSS now. He said TP packs too much internals into the can not leaving enough free space for cooling.
    • zooma
      Local club FE racer
      • May 2014
      • 653
      [ATTACH=CONFIG]177940[/ATTACH]
      Paging Dr. Huff. Please report to the drivers' lounge.
      Ron - The Villages, FL
      • Panther6834
        • Apr 2020
        • 708
        Originally posted by HTVboats View Post
        post #6 all you need to know
        You mean, post #5? Post #6 is just another question from the Op.
        • donhuff
          • Dec 2014
          • 561
          Ron Farcus,
          I just got home after driving 3608 miles across the middle of the US. I'll try to respond tomorrow, but right now I'm gonna drink my Jim Beam and Coke, sit back and relax. See ya'll later.
          AmpDaddy
          don huff
          • zooma
            Local club FE racer
            • May 2014
            • 653
            Originally posted by donhuff View Post
            Ron Farcus,
            OMG, what a time you must have had. Been following the news on U-tube. Ready to send a couple of motors, I'll start packing.
            Personally, I'm a Canadian Club Old Fashioned guy. On number one right now.
            • tjsb
              • Mar 2023
              • 478
              Something I have just found is that TP is the only company to build large high kv motors.There 3650 is 36 x 84 at 3850kv or 5600kv why call it a 3650?.The other motor company's dont have motors this large at these kv numbers so they cant come close to there power.Am I missing something here?
              Thanks Tom
              • donhuff
                • Dec 2014
                • 561
                Tom,
                This is an area of confusion that every motor buyer has to deal with. There is NO standard for how the different motor brands describe the dimensions of their motors. Even though probably 80% of all the motors made, are made in one building in Hong Kong, it seems to be left up to the motor wholesaler how they are going to describe their motors.
                For TP 36mm is the diameter of the case, and 50 is the length of the rotor
                Leopard, SSS, and several others say 3660. That's the diameter of the case, and the length of the case. The rotor might be only 30mm long (SSS) 32mm long (Leopard) 35mm long (dynamite 2000)
                Then Tenshock has a 38mm diameter motor case but they describe it as 2240, That's the actual rotor diameter and length. Lehner does it this way also. This is the most valid way to describe it in my opinion.
                A lot of the non name brand motors sell you a lot of AIR. They'll have a big case, with short internals in it, and very inflated specks too.
                If a motor is cheap, there's usually a reason for it, Air is CHEAP!
                AmpDaddy
                don huff
                • donhuff
                  • Dec 2014
                  • 561
                  Tom,
                  About the high KVs offered by TP. They are trying to make motors available to whom ever wants one, for whatever the application. Most of the other companies offer the most useful kv for the most typical applications, ie cars ,boats, and airplanes. And for the most popular voltages 4,6,8,10,12
                  Tp has more higher kvs that will work better with 2S (8volts) And Lehner, has more kv options than you can count!
                  AmpDaddy
                  don huff
                  • Bande1
                    • Mar 2023
                    • 678
                    note the TP 3630 is a 3660 case with a 30mm rotor.
                    • tjsb
                      • Mar 2023
                      • 478
                      So the TP motor 3650 3850kv was not any faster then my amazon 3650 4000kv.The motor didnt heat up at all but pulled a ton of amps?Did I get to large of a motor for a 2s rigger?
                      Thanks for the info
                      Tom
                      • NativePaul
                        Greased Weasel
                        • 2770
                        TP 3650 is a lot bigger than I would fit in a 2s rigger, a TP 2935 4970Kv is more my style (i switched to 3s before TP gained popularity as the class i race in started allowing 2s or 3s with the same battery energy, and the higher voltage is a little more efficient, so my last 2s boat was a modded JAE.12 with a leopard 2860 5200Kv); but I won't say its wrong, if your 2s rigger is a lot bigger and heavier than mine were, possibly with 2s2p and you have a stock of props for 4-6s boats, it might be well suited to you.
                        • tjsb
                          • Mar 2023
                          • 478
                          Thanks
                          • tjsb
                            • Mar 2023
                            • 478
                            After some more testing this is what I think of this tp motor.All things the same in my 3s rigger the tp motor has alot more power than the amazon 3670 3050kv motor,with the same prop they ran the same speed but the tp motor pulls about 30% more ampage.The tp will handle a bigger prop for more speed than the amazon motor but run time is cut in half.It is a good time trial motor.I would like to know if the smaller tp motors would run the same way or do they all pull a ton of amps?
                            • tjsb
                              • Mar 2023
                              • 478
                              Also where can I buy leopard and sss motors?
                              • Panther6834
                                • Apr 2020
                                • 708
                                https://www.offshoreelectrics.com/ca...php?cat=Motors
