Important Questions
  • Flying Scotsman
    Fast Electric Adict!
    • Jun 2007
    • 5195
    Originally posted by txboatpilot View Post
    4S lipo and a Neu 1521 for a 39" hull??? Guy's is there something I am missing here??
    Just voltage . He has not stated his end voltage as of this date
    Douggie
    • ED66677
      • 1300
      6S would be better for a 39" hull!
      Emmanuel
      • txboatpilot
        • Oct 2007
        • 1805
        I run a 40" Insane Cat, on 8S2P and 10S2P.. Speeds range from 40-45mph on 8S and 55-60mph on 10S....
        Does anyone here, have any video or data on large 39"+ hulls running on 4S or 6S??
        Any pictures of the 39" hull??
        • hide
          • Dec 2008
          • 188
          Sorry guys, I meant that I was looking at a pair of 4s batteries; I doubt a single 8s or 10s battery will fit under the lid, so I was looking at a pair of 4s batteries (the SMC's obviously aren't enough)
          Hull's nearly done, needs another epoxy layer and it should be ready. On exam leave until Monday, so I'll upload photos relatively soon :)
          • hide
            • Dec 2008
            • 188
            Guys, I intend on running 8s Lipo, but the Hydra 120/240 doesn't allow this, so I have to use the HV version. Or, can I run 8s and a seperate BEC with the Hydra 240?
            • tth
              • Apr 2008
              • 1600
              the Hydra low voltage series will not handle 8s. You will need to get a HV esc.
              • hide
                • Dec 2008
                • 188
                Ok guys, I've ordered:
                CC 120HV Hydra ESC
                Neu 1521/1Y 1577KV 8mm Shaft
                OSE 8mm Straight Couplers for .187 cable - Out of Stock, will make my own on the lathe
                Hughey .187 Assembled Cable for 3/16" Propellers
                Teflon Liner for .187 flex cable
                9/32 brass for Octura .187 Teflon tubing
                Speedmaster Stinger Strut for 3/16" prop
                Speedmaster 21 Rudder 5.25" Long Mono Rudder
                Octura x447 Prop 3/16"
                Hopefully the Hydra will be okay with this setup, I've calculated that the Motor will draw 118 Amps max on this motor. I'm going to only use this in this hull once or twice quite lightly just in case though. Then it will be going in a smaller/lighter hull.
                • Meniscus
                  Refuse the box exists!
                  • Jul 2008
                  • 3312
                  If your calculations come up to 118 amps, I would be very cautious. Consider starting with a smaller prop and record the amp draw on the system. Others will record temperatures, which I would do anyway. This way, you don't cook an ESC that is not easily replaced due to funds. Just my thought.
                  What does everyone else think? I haven't crunched his numbers, but I figure it is worth mentioning before he cooks something.
                  • txboatpilot
                    • Oct 2007
                    • 1805
                    Where are you coming up with 118amps?? Please dont tell me it is the FECal?
                    The only way too know the amps for sure is to run a Data logger...
                    • hide
                      • Dec 2008
                      • 188
                      I got a car friend of mine to do the numbers for me, working out the max amps using Watts/Volts; not sure if it is correct though.
                      I'll need to find a UK shop, since I don't want to have to order a prop all the way from the US. The Duty & VAT is killing me!
                      • Flying Scotsman
                        • Jun 2007
                        • 5195
                        Wow 8S on a CC 120HV and that motor. The RPM will be in the region of 44,000 RPM.
                        I do not think this is a wise choice.
                        Douggie
                        • hide
                          • Dec 2008
                          • 188
                          Ouch, lucky I haven't got the batteries yet. Will 6S be a better choice?
                          • Flying Scotsman
                            • Jun 2007
                            • 5195
                            Have you purchased
                            the ESC and motor?
                            Douggie
                            • hide
                              • Dec 2008
                              • 188
                              Yes, I was suggested by CC to use that ESC and Motor, along with that prop.
                              • Flying Scotsman
                                • Jun 2007
                                • 5195
                                Did they know you are going to run a 39" hull of your own design...wood and fibreglass and I presume a mono hull. CC is great on info for cars, boats not so good.
                                Douggie
