Help with esc
  • Jalopy
    • Oct 2021
    • 15
    Help with esc
    Can not get OSE 150 Raider esc to connect to Leopard LBP4082-B .Using two 5000 MAH 4s 65c 14.8v 74 Wh battery pack.Could you point me in the right direction with a video. Any help would be appreciated. A newbie at electric boating always used gas powered motors. Thank You
    Jalopy
  • oscarel
    • Dec 2009
    • 2373
    What do you mean by connect to??
    Sent from my SM-S908U using Tapatalk
    • TRUCKPULL
      • 3293
      First thing is to pair your receiver with your radio.
      Next is to pair your ESC with your radio.
      Instructions are with the ESC box or online from OSE.
      Larry
      • zooma
        Local club FE racer
        • May 2014
        • 653
        Assuming that the receiver is bound to the transmitter, there are four easy things to check. Is the throttle trim set to midway or less? Is the ESC plug backwards in the receiver socket? Is the plug in the correct socket? Have you done a throttle travel calibration to the ESC?
        Ron - The Villages, FL
