rc catamaran cheeta prop walk problem
  • tjsb
    • Mar 2023
    • 478
    turns right alot,will shimming the strut bracket fix it?
    Thanks Tom
    You can try and then you will find out.
      • 4338
      Single, twin, prop size, is it sharpened and balanced... pictures would help too.
      • Peter A
        • 1622
        Yep pics of your setup. Too big a prop, strut too low, small rudder can all be a cause of the problem.
          A skeg strut could help.
            Sounds like a single when he mentioned shimming "the" strut bracket. Most twins don't have prop walk issues unless you really went wrong on too big of props.
              • 4338
              I missed the "Strut" comment, but driveline friction, motor kv mistmatch, prop damage, plenty of things to make a twin pull to one side. And since we have absolutely nothing to go on, why not think Zebra instead of horse...
              • tjsb
                • Mar 2023
                • 478
                1714 prop,single motor,6s,
                Thanks tom
                • Speed2
                  • Jun 2023
                  • 48
                  Does the rudder have any play, is the steering trim set to keep the boat running straight. A low torque servo can contribute to that problem too.
                  Is the prop properly balanced.
                  Hopefully reading all the responses will help you solve the problem.
                  • koen
                    • Mar 2020
                    • 367
                    If you can hear 2 motors run they are not in sync that can be a problem
                    • photohoward1
                      • 1781
                      need pictures. I run on 4s with a 452/2 prop. No prop walk issues. it's a screamer. Run the bottom of the strut up from the sponsons about 1/8 to a 1/4"
                      Sounds like the struts to deep. BTW it hated the new ABC series props. Old school Octura, balanced, sharpened and de-toungued.
                      • tjsb
                        • Mar 2023
                        • 478
                        How fast on 4s,after the strut change I hit 55 and thats with nose in the air.With strut change I dont have turn the rudder so much to go straight.
                        • tjsb
                          • Mar 2023
                          • 478
                          Any other ideas would be great
                          Thanks guys
                          Tom
                          • Peter A
                            • 1622
                            A skeg strut, as Ray suggested.
                            • Rlimits
                              • Jan 2019
                              • 82
