Soldering T plugs?
  • TRUCKPULL
    • 3293
    Soldering T plugs?
    What is the best way to solder two plugs to an ESC in a "T" configuration?
    also how do you put heat-shrink on them?
    Larry
  • Panther6834
    • Apr 2020
    • 708
    What do you mean "in a T configuration"? Are taking about 'parallel', or 'in-series'?
    ~ More peace, love, laughter, & kindness would make the world a MUCH better place
    • TRUCKPULL
      • 3293
      Two sets of two plugs for Parallel connection. two 4S -5000 packs in parallel.
      Larry
      • TRUCKPULL
        • 3293
        A picture is worth a thousand words.
        The red and Black wires are coming from the ESC.
        Larry
        • Panther6834
          • Apr 2020
          • 708
          So, parallel...in other words, the voltage into the ESC from two packs three same as the voltage from a single pack, but doubling the capacity (ie. the ESC will "see" two 4000mAh 2S packs as if it were a single 8000mAh 2S pack).
          Honestly, don't try to create this T design. You will be MUCH better off soldering a traditional parallel design, with each side (positive & negative) going to a Y, with the bottom of the Y going to the ESC, and connectors on each side of the top of the Y. See image.
          • properchopper
            rcgoatbuild@snotmail.com
            • 7708
            Hi Larry
            a bit time consuming to construct, but way quick/easy in the pits :
            • properchopper
              • 7708
              • TRUCKPULL
                • 3293
                If you look at my picture below.
                I am thinking about turning on the lath, a piece of solid copper down to fit into the back of the plugs, and solider them so that they are toughing each other.
                I would then drill a hole the required size of the ESC wire, in the middle between the two plugs for the ESC wire.
                The other question then is how to shrink wrap it?
                Larry
                • Peter A
                  • 1622
                  "The other question then is how to shrink wrap it?"
                  Liquid electrical tape.
                    You could encapsulate with epoxy.
                    • TRUCKPULL
                      • 3293
                      I would still like to take it apart if I had to.
                      Larry
                      • TRUCKPULL
                        • 3293
                        Robb
                        I have done my ESC's like this for years.
                        I would like to try a "T" connection.
                        Thank You
                        Larry
                        • TRUCKPULL
                          • 3293
                          different angle[ATTACH=CONFIG]177049[/ATTACH]
                          Hello Tony
                          That is the right idea.
                          But I would like it a little more compact.
                          Larry
                          • Panther6834
                            • Apr 2020
                            • 708
                            Originally posted by TRUCKPULL View Post
                            Robb
                            Thank You
                            Larry
                            Got ya...no worries. Best of luck. [emoji1360]
                            • TRUCKPULL
                              • 3293
                              First part of my "T" connection is done.
                              Copper pieces turned down and soldered.
                              Larry
