Well, I had to ask , strut bearings vs bushing vs Teflon , non racing applications for sport hydro. What say ye? for 3/16 flex.
strut bearings vs strut bushing vs Teflon liner
It depends what you are looking for. For max efficiency ball bearings and Teflon with oil for lube. But flex and bearings need cleaning out and re-oiling after every run, and bearings will need replacing periodically. For ease of maintenance no Teflon and a floating bushing will last nearly forever, and the shaft just needs cleaning an re-greasing every few runs or at the end of the day.
Alternatively wire drives are the bomb as long as you don't have a tight bend.Paul Upton-Taylor, Greased Weasel Racing.
Don't use regular WD40 as a lubricant, it isn't one (though it does have some minor lubricating properties). Having said that I use WD40 branded PTFE loaded lubricant as i find the smart straw system convenient, but sewing machine or 3in1 work fine too. I haven't tried gun oil but from what i remember it is stinky stuff and probably more about corrosion resistance than lubrication.Paul Upton-Taylor, Greased Weasel Racing.
It is a high RPM bearing oil, I use it on all my motor bearings.
So why not use it on Ball Bering's in a strut.
LarryPast NAMBA- P Mono -1 Mile Race Record holder
