TFL twin drive transfer case in a mono
  • LarrysDrifter
    Big Booty Daddy
    • 3416
    Has anyone used the TFL twin drive transfer case in a larger mono hull? Say 38? - 45? range? I was thinking of using two 40mm motors and going single drive, using 6S power. I?ve been searching and haven?t found any info useful to my question. Not going for a SAW build, just something different and for sport use.
    Any info is appreciated.
    In my experience I would just get one appropriate sized motor. Matching two motors coupled with losses running thru a set of gears is not worth it. Boat will run quieter as well. I did this years ago when all we had was brushed 540 motors but now with all the choices in motors there i# no point in complicating things.
    Now if you wanna go one motor into two props that’s another subject. I have a drag hydro that I am going to do this with. These are my thoughts on the subject, thanks for reading.
    Shawn
      • 4340
      I agree with Shawn. Make it a true twin, or a single. If you want to mess with a transfer case, stick with a single motor and two drives.
      • LarrysDrifter
        Big Booty Daddy
        • 3416
        Thanks for the responses, I appreciate the feedback. Might just stick with single drive.
