Coupler size help
  • Woohoo\o/
    • Jan 2023
    • 67
    Coupler size help
    I'm new to boating needles to say. I'm having a marvelous time understanding coupler sizes. I need a coupler for the following setup.
    Motor shaft: 5mm
    Flex shaft: 4mm
    So I'll need a coupler that's 5mm to 4mm flex shaft is this correct? Is that sold here? Can someone point me out?
    Thanks and happy 2023
  • koen
    • Mar 2020
    • 366
    OSE sells them and every thing you need
    • tbonemcniel
      • Sep 2020
      • 294
      Right here on OSE: https://www.offshoreelectrics.com/pr...prod=ose-81513
      • CJPB32
        • Aug 2022
        • 72
        Open the sales items page here at OSE.
        Product ID ose-81513
        In Stock 20
        OSE 5mm to 4mm Collet steel coupler
        • Woohoo\o/
          • Jan 2023
          • 67
          Awesome thanks. So just for learning purposes what is positive rotation and negative rotation when purchasing a coupler?
          I know it's the direction the drive system rotates. But which is which? Positive = clockwise?
          Sorry for the noob questions.
          • Woohoo\o/
            • Jan 2023
            • 67
            That clears it up for me thank you.
            • Panchothedog
              • Oct 2015
              • 173
              Never heard of the right hand rule. I guess it works. Sounds quite confusing. Look at the boat from the back. Looking at the transom. Standard rotation is ccw. If you are running twins then you need a reverse wound flex cable and a prop usually designated with a R at the end of its size. Both are appropriate cw rotation. Actually quite simple.
