first outboard
  • rainfly
    • Aug 2015
    • 38
    first outboard
    happy new year! i am starting a tunnel build (zippkit 30) i have never built an outboard and have a motor/battery question, please. is it better to run a 4s with a 2200kv or a 6s with a 1600kv. im not a racer, but i want demon speed..36-40 and no bigger than 72 max..please advise. TY
    • 7651
    This all depends on the room in the hull and where you want the weight, also which batteries one has on hand may influence a decision. Both those choices are good. I usually find 4s packs easy to place.
    Shawn
    • JestDanny
      • Jan 2017
      • 176
      I have a similar hull the old Aquacraft VS-1. I run it on 4S with a 120 amp ESC. With a good quality 36 mm x 60 mm 1950 to 2200 Kv motor atop a race style lower, I use OS, spinning a X640 or X442 prop the boat runs mid 40's mph solid, stable. Good run times too watch temperatures.
      I put the electronics in rear an battery up front, battery can be moved a little fore or aft to trim boat. happy rooster tails
      PROBOAT BlackJack 24", ShockWave 26"
      MRP U-31, 3 tunnels VS1, MRP Bud Light, Dumas HS Sprint
