Cheetah xl - hull problem??
  • Mike W
    • May 2018
    • 348
    The hull running surfaces are concave front-to-rear. A massive amount of work is required to correct this. Put a straightedge on it and you will see the center two running surfaces lower than front and rear. The concave portion causes it to stick to the water anytime the nose drops even slightly.
    Otto RC Marine
    • Silver954
      • Feb 2016
      • 69
      If you post pictures it will help visualize what you are saying
      • Mike W
        • May 2018
        • 348
        Set it on any flat surface. Observe where the hull contacts the table at the end of each running surface. There are 4 on each side. All 8 should touch the table at the same time. On every hull I?ve seen the middle two on each side are high. I think the hulls warp. You could try a bulkhead? Always check for twist too.
        Otto RC Marine
        • MikeP323
          • Jul 2015
          • 96
          Clarification to reply re Cheetah XL
          Mike - Is this a problem with all Cheetahs or just the XL in particular? Then u mentioned trying a bulkhead which I am not familiar with either. I am still fighting the battle with this hull which has been blueprinted by a friend with no tangible results. Thanks for your reply!
          • Mike W
            • May 2018
            • 348
            Just the XL. And possibly also because of the additional step that no other cat I have ever seen has. The bulkhead comment was a suggestion to possibly stiffen the low area to the deck to make the repair more stable.
            In most cases blueprinting is smoothing the existing running surfaces to flat and squaring edges. If they are not true to start with there is a great deal more work that needs to be done.
            Have you placed it on a flat countertop to observe how true the running surfaces are?
            Otto RC Marine
            • MikeP323
              • Jul 2015
              • 96
              Still working it - Cheetah XL
              Yes I have and it still needs more work on the bottom thats for sure. I did find that one of the two motors was faster by 1744 rpm (no load) and so they are now matched with a new one to match the other new one already installed. (within 10 Kv.} Funny that the installed used motor had a higher Kv rating than the new one. I dont know if the matchup will help but it cant hurt. As to the bottom I believe I will need an expert in the booth with me.
              Thank you for your reply! MAP
              • Notoriousone
                • Oct 2022
                • 69
                Just guessing here, but you mentioned that you adjusted the struts up a degree, maybe try 1 more degree up? Are you using lifting props? If so, maybe some non lifting props and a slight upward strut adjustment would help to get the bow up. I also think large fiberglass RC boats can come out of the mold straight, but then slowly warp especially if there is no Carbon or Kevlar lining
                • MikeP323
                  • Jul 2015
                  • 96
                  Still working it!!
                  Thanks for your reply Notorious. Yes I have tried the struts at all reasonable angles. Now to lifting props. I have tried ABC three blades and detounged CNC two blades to no avail. What type props make the least lift? I am about to try a small aluminum blade at the nose to give it the bit more it needs to get up and stay up. I have used blades to put some downforce on cats but this will be the opposite. Have to drive it with the throttle then for sure I think. When it does get up it flies.
                  • Silver954
                    • Feb 2016
                    • 69
                    Big cats handle like a drunk noodle at low speed. They have to be on top of the water going to act normal.
                      A set of Octura 447’s should be a good all around choice here. Low on the lift. This is my go to on my R42 cat which is similar in design, ( ie: wide body). The ABC props you have, are they SK series? If not then most other ABC props are of high lift. They SK series will actually push the nose up (or push transom down depending how you look at it). What you seem to be experiencing is the old Geico hop or porpoising. It is a combination of small things to get past this.
                      You may also be onto something with ‘the blade’ in front of tunnel. The tunnel design can also effect things.
                      Have you tried an air dam under the tunnel? This is commonly done with a windshield wiper blade taped to the underside of tunnel a couple inches back from the leading edge of the tunnel. This will create turbulence within the tunnel and sometimes helps.
                      Aerodynamics comes into play on anything over 35mph so on our light little boats doing 50-60+ just imagine.
                      Just sharing thought# and experience here, Shawn
                      • JOHN BOCCHER
                        • Apr 2021
                        • 12
                        Hello every body, I am looking for some expert advice for those of you you that have a lot of experience with the TFL cheetah XL . I am about to give up on this hull if I can't get it fixed over the winter months.
                        First a little history. I bought the Cheetah directly from TFL . To run in our club under Q cat Club and IMPBA rules which are as follows. Max hull length of 40 inches . The hull just makes that rule as my hull is 39.75 inches. I must use a 40 mm x 92 mm single motor and run on 6s Lipo battery. and limited to a 50 mm prop. TFL now sells this version with a SSS 40 x 92 mm 2140 kv motor. So I originally went with that.For added strength they added the Kevlar to the hull with water pick ups in the bottom rear sponson. When the hull arrived they had the battery trays mounted as far forward as possible in the hull. I have already moved them back but not enough yet.I was burning up 200 amp ESC. It was suggested that I switch motors to a TP 40 mm x 92 mm and a 1350 kv and use a Castle XLX2 manba hydra 180 amp ESC. I have tried up to a 445 prop with the flat bottom strut up 1/8 inch from the bottom of the sponson. The hull runs very very wet and only hit 41 mph.
                        I can only get to boat to balance at 13 inches forward of the transom.
                        I am now in the process of moving the battery trays back as far as I can . I could get another 1 1/2 inches further back if I remove the dual bottom sponsom water pick ups and just stay with my dual water pick up rudder. With the Castle ESC relocated toward the rear behind the motor it would just fit between the shaft tube and the servo radio tray. This will allow me to get the GG back to 11 1/2 inches forward of the transom.
                        If I remove the bottom water pick ups I could gain another 1 1/2 of battery movement to the rear if need be. This hull weighs in at 12.5 lbs. ready to run.
                        After ready many post here on the design flow of the sponsoms, I check mine and they are off big time. I can see why the bot is stuck to the water.
                        So, I guess from here what would the best motor kv be if I stay with my new castle ESC ,or am I looking at another new larger amp ESC. ?
                        What would be the best CG location for the configuration. ?
                        Also should I install a rudder extension to move the rudder back off the transom ?
                        I need to find the site with pictures that shows me what the corrected sponsons look like.
                        Thank you all for any help you can give me in advance.
                        Signed frustrated .
                        • Bande1
                          • Mar 2023
                          • 678
                          post a pic of your data log
                          • koen
                            • Mar 2020
                            • 367
                            maybe this helps:set the strut 1/8" above the sponsons and if you need lift at the front use ABC 1815-17 this prop you can use it for a start and put the battery try's next to the motor(the motor you use is exellent)and also you can give the strut up angle (just a bit and adjust when need)
                              Signed frustrated .
                              If your ride pads are convex at all it will run wet. They should be ?blueprinted?. They should be flat with a very slight dihedral(like 2-3degrees). Until this is checked or done you cannot make proper adjustments with consistency. As stated the ABC props will lift the nose.
                              Shawn
                              • JOHN BOCCHER
                                • Apr 2021
                                • 12
                                Hull problem
                                Hi Bande1,
                                I don't know how to do that but i can type the info you would like. I have found other problems with the bottom of the boat. They steps are all different . Two on the right side are low and the middle step on the left side low low by about an 1/8''. I need to fix them first.
