22 inch hydroplane setup
  • U.L. HYDRO DRIVER ICE
    • Apr 2008
    • 270
    What would be a good motor and a esc for this boat . I would like to get around 40mph + and how many lipos should I use thanks for looking 22 inch hydroplane setup
  • JimClark
    • 5913
    I have a 1/16th shovelnose that has a 3600 kv Ammo motor and uses a Hacker 70 and a 2s lipo with a Octura X430R prop and it is close to 40 cretainly higher than 35. If you used a 3S and a lower KV I think you would be at 40 or slightly above. Boat is 22.5 long
    Billy Graham
      • Apr 2008
      • 270
      Which model is he motor or the mm thanks
        • Apr 2008
        • 270
        What about using a hacker 8 L 3000 kv and a 100 amp esc with a x435 prop on 2s
        • JimClark
          • 5913
          Here is the link for the motor
          http://www3.towerhobbies.com/cgi-bin...9&I=LXLWY5&P=K
          Not sure on the hacker
          Billy Graham
          • JimClark
            • 5913
            Charles what Hydro do you have hat is 22 inches long?
            Jim
            Billy Graham
            • Steven Vaccaro
              Administrator
              • 8934
              Here is a setup for ya.
              http://forums.offshoreelectrics.com/...ead.php?t=6143
              Steven Vaccaro
                • Apr 2008
                • 270
                Jim
                It is a 22inch budweiser that 90 s hull
                  • Apr 2008
                  • 270
                  How good would this motor do
                  Great Planes Ammo 28-56-3200 In-Runner Brushless Motor and which prop
                  • JimClark
                    • 5913
                    Porbably have a whole lot of torque so you would most likely be able to handle a much larger prop than my boat can. My boat uses a X430. Never used one but it could work.
                    Jim
                    Billy Graham
                      • Apr 2008
                      • 270
                      Do you think a x 435 would give some speed
                      • JimClark
                        • 5913
                        Would be worth a try on that outrunner. run it for a short time then bring it back in t check temps
                        Billy Graham
