Hi all just purchased a Weller 80 watt heavy duty soldering iron to solder 6mm bullet connectors on the smaller irons i have just wiped the tips with a damp sponge and re-tinned them on this iron they suggest brass wool to clean the tip . Which method is the proper way of maintaining solder tips ? Regards Andris Golts.
Maintaining and tinning the soldering tip ?
Tags: None
We use both at work . The big thing with sponges is to make sure they are not sopping wet. Squeeze the water out of them before use.
https://www.amazon.com/Aoyue-Solderi.../dp/B005C789EU
Sponge first. If it doesn't do the job then go to the steel, brass or copper type sponges. I buy the metal ones at the dollar store.
If I knew you were in the market for a good Iron I would have given you a deal on an Atten ST-2080D https://www.atten.com/product/st_2080d_soldering_iron You can tips through them direct or Ali Express.
I use the ST-2150D and it's slick!!!
