5 inch T Bar and Oiler Can
  • racerr73
    • 133
    Hi,
    Just wondering what size hole should be in the bottom (inside the 6mm thread) of a Oiler can secured onto a 5 inch T Bar. The one i have purchased has a .5mm hole in it and has no chance of allowing oil to go through it. Also what size hole should be drilled into the 5/16th stuffing tube to allow the oil through.
    Thanks in advance
    Trevor
  • CDIIdp
    • Jan 2022
    • 1
    I also wandering the same size obstacle and fishing line Dubai
    • racerr73
      • 133
      So with over 60 views and no replies i take it no one uses this method of oiling for there flexshafts.
      Trev
      • RayR
        @SiestaKey.calm
        • 1518
        The hole size depends on the oil viscosity. For example, many use a 1/16 hole and Mercury lower unit lube (90 wt gear oil).
        • racerr73
          • 133
          Hi RayR,
          Thank you for your reply, that gives me a good start.
          Trev
