P-spec mono !
  • Andris Golts
    • 508
    P-spec mono !
    Hi all setting up my 32 inch Warlock mono 4s power UL-1 motor x442 prop twin trim tabs with starboard inner tab bent down 1/16 of an inch both turn fins set straight and rudder set straight. When running the mono the hull pulls severly to the right. What other things should i be checking to resolve this problem ! Regards Andris Golts .
  • jkflow
    • Aug 2021
    • 329
    What is severe? i.e. can you trim it out with a couple of tics? That is normal.
    Check that your strut is straight and didn't get bend or similar.
    Both trim tabs should be roughly the same, you are creating drag on starboard and nothing on port, that would do it as well.
    Flip the boat over and look for any anomalies.
    • Andris Golts
      • 508
      Thanks jkflow for your reply. Regards Andris Golts.
      • Jesse J
        scale FE enthusiast
        • 7818
        Check servo rod for stiffness and servo for adequate strength.
        "Look good doin' it"
        See the fleet
        • zooma
          Local club FE racer
          • May 2014
          • 653
          Sounds like it's hooking to the right. Maybe running bow too low. Try moving the batts back to shift the center of gravity aft.
          Ron - The Villages, FL
          • Jesse J
            scale FE enthusiast
            • 7818
            Please share pics of linkage and rudder set up
            See the fleet
            • Andris Golts
              • 508
              Thanks for replying to my thread. Regards Andris Golts.
