Hi from across the pond here in the UK. I am just about to build my first Cat ,a single motor 34" TFL Cheetah (from OSE).
My question is the position of centre line of the prop /strut hub in relation to the bottom of the hulls when set parallel, both of my fast 30+inch mono's a Pursuit and Hydra (identical to the Dominator ,UK version
) the centre of the drive/prop sits between 8 and 10mm above the lowest part of the V or hulls as per Cat...does this measurement work for a single motor Cat??...sorry if this may sound a basic question and may well be answered deep into this forum but i think i may go blind trolling through the masses lol
ps just out of interest im not looking for massive speed as the size of my club puddle dictates anything above 70mph is somewhat butt clenching
hence my choice of single motor on parallel 4s.not knowing the water flow between a Cats hull the last thing i need is drag from a wet drive hub.
Look forward to any advise .thanks from Limey Les
hence my choice of single motor on parallel 4s.not knowing the water flow between a Cats hull the last thing i need is drag from a wet drive hub.Look forward to any advise .thanks from Limey Les
