Hi all i am in the process of starting to build a ML boat works FE 34 inch Wild thing mono hull .I would like to set this boat up using 6S power i have a Swordfish pro 220 amp esc with 6 mm bullet plugs . What size TP motor and KV range would be most suited for this application . Regards Andris Golts .
Which TP motor should i buy !
Tags: None
TP 4050 1570 kv, it can get you at 100kph range with a 45-47 mm prop. I have run one in my DF Pirate 35" at those speeds.NZMPBA 2013, 2016 Open Electric Champion. NZMPBA 2016 P Offshore Champion.
Andris - to come up with a sensible package (as in building a sprint racer that can go mill + 6 +1 ) on a 1/6 mile course I'd adhere to the good old chart for KV vs Voltage.* To keep your 6S rpm in the "golden comfort range" a TP Power 4050 5Y [1330 kV ] will yield @29500 at the prop unloaded. Nice handling in the 50 mph range. The TP Power 4060 4Y [1350 KV ] will yield @ 29,900 at the prop unloaded and will pull lots of prop to get you up around the 60's.
*Attached FilesLast edited by properchopper; 10-04-2021, 09:04 PM.2008 NAMBA P-Mono & P-Offshore Nat'l 2-Lap Record Holder; '15 P-Cat, P-Ltd Cat 2-Lap
4060 motor is big and heavy (34" hull)
, prefer a 4040 (40mm x 74mm) TPPower motor 1500kV to 1700kV with a 6S setup.
A 4050 - 82mm length would be on the ragged edge but manageable. 1400-1600kv for sure. We have guys using 4040 74mm length motors for our Q limited racing running high 50's easily. A great match for a 34" hull with longer run times. 120-140 amps on 6S.
Mic
Mic Halbrehder
IMPBA 8656
NAMBA 1414
Take Tony's advice. If you plan on running a heavier 2P setup the 4060 is the way to go. If you run a lighter weight 1P setup go with the 4050. I would stick to the lower end of the KV range. 1200-1400 will allow 44-50mm props.Tyler Garrard
NAMBA 639/IMPBA 20525
T-Hydro @ 142.94mph former WR
I run that TP motor in my Q hydro. We have a max limit of 6000mah for the class here. It runs around 65 mph on an ABC 1915/45/17 prop. I can do a heat race on 5500mah batts like this.
I tried also the TP4050 1570 motor in the same boat with an ABC 1814/45/17 and managed 70mph on the oval with the gps.NZMPBA 2013, 2016 Open Electric Champion. NZMPBA 2016 P Offshore Champion.
I cannot tell you exactly, but it has a V2 T-180 esc and I am able to do a 5 lap + mill heat race with it on 5500 mah. So it has it has to be around 110A average draw. I have no datalog, nor do I care for one. What natters is how fast I get it to go and how many mah go back into the batt. I don't like going below 20% and it is right there with the setup.Originally posted by Troy1957 View PostPeter what kind of amps are you pulling on both of those setups?NZMPBA 2013, 2016 Open Electric Champion. NZMPBA 2016 P Offshore Champion.
Both. I was running a ZTW 200 but changed to the T-180 to lose a bit of weight.Originally posted by Troy1957 View PostPeter which motor with the v2T180????NZMPBA 2013, 2016 Open Electric Champion. NZMPBA 2016 P Offshore Champion.
