Mono build
  • Skeet
    • Mar 2017
    • 15
    Mono build
    Hey guys, hoping I could get some recommendations on a mono hull to start a build on. I am looking for advise on hulls in the 48 to50 inch size. Been looking at MHZ hulls as well as the ML Boatworks mono but am open to others. I am wanting something that can handle a little rougher water than my Zonda can handle. I am limited to early morning or just before dark with the Zonda presently. I am sorta leaning toward the MHZ Ocean Spray but am open to other recommendations from more experienced builders. Thanks,
  • Jesse J
    scale FE enthusiast
    • 7818
    Seaducer has a pretty sweet looking mono around that size.
    Doesn’t sound like you will be racing?
    "Look good doin' it"
    See the fleet
    • Skeet
      • Mar 2017
      • 15
      Thanks, I will look at the Seaducer as well. No racing just sport running.
      • eehess81
        • Jun 2021
        • 158
        What about the delta force DF90, 49.5". OSE sells it, very happy with my DF23.
        • Peter A
          • 1624
          How Rough water are we talking about here? If you are talking 2-6" chop then depending what your goals are a 36-44" hull on 6-10s will be fine if you are just bashing about. Set up and balance are as important as size in rough water.
          • properchopper
            rcgoatbuild@snotmail.com
            • 7708
            Designed to thrive in gasser racewater
            The new 48" Insane Mono, part of the new "SYNERGY SERIES" molds. 48 x 13, fully enclosed, with cowl. Related products below.
            • Skeet
              • Mar 2017
              • 15
              I like the looks of the Insane Synergy. Thanks
              • properchopper
                • 7708
                Take a close look in the video screenshot at the front deadrise as the boat passes on the front straight; the wetted surface is short for a 48" hull - less wetted surface = less parasitic drag = less power consumption/more speed. These hulls are specifically made for IC racing and are way studier than a Chinese hull (not that there's anything wrong with Chinese hulls). Be interesting to see how a FE version would turn out
