Ok, silly question time. I have a Leopard 4082 motor with a cooling jacket mounted in a water cooled mount. Which should I route the cooling water to first, the jacket on the motor or the fittings on the mount. I've thought about it a lot and don't see much difference, but I thought I'd at least ask. Thanks.
Routing cooling water lines
Tags: None
definitely motor first! Having direct water on the can is going to cool more efferently than the transfer of heat from the end bell to the motor mount.
+1 to what Mike said. Cool the motor can, then the mount.Tyler Garrard
NAMBA 639/IMPBA 20525
T-Hydro @ 142.94mph former WR
Personally, I would bypass the mount all together. I pull the barbs and thread in grub screws so I don't have to look at them. The passages through those mounts are usually quite narrow and restrictive to flow. I'd rather have increased water flow through the more efficient jacket and a shorter cooling path overall.Vac-U-Tug Jr (13mph)
