Antenna wire broke
  • Spat
    • May 2020
    • 31
    Antenna wire broke
    Lost power in the lake, good Samaritan in his fishing boat picked it up by the antenna, broke the wire. Only about 4" left. Can you splice the wire together. Receiver is an older Futaba crystal type R152JE. Any info on repairing or replacing.
  • dasboata
    • Dec 2010
    • 3972
    yes splice it if the old 75 MHZ 32" or so ant I forget now !!
    • Spat
      • May 2020
      • 31
      32? Thought I should keep it as close to the original length.
      • dasboata
        • Dec 2010
        • 3972
        yes I didnt think I had to tell you that , If I remember correctly it's around 32"
        • Spat
          • May 2020
          • 31
          I would if it was that long. That's why I asked. It's only 12" max, haven't measured the actual yet.
          • KNUJ11
            • Jun 2021
            • 7
            75MHz receiver uses a 20" antenna wire
            • Spat
              • May 2020
              • 31
              Thanks, got a little worried when I was told it was 32. Did measure it and it was about 20 long. Minus the 1/2" to splice it back together
              • KNUJ11
                • Jun 2021
                • 7
                You are fine, this is not an exact science. 75MHz wavelength is 1016" (4m metric) and these are at 1/64 which is roughly 16", a couple inches are for routing etc.
                Enjoy the ride.
                • Spat
                  • May 2020
                  • 31
                  Thanks, greatly appreciated
