Installing battery connectors
  • Spat
    • May 2020
    • 31
    Needs lots of help here... using QS 6 connectors and got the soldering done but cannot get the covers on. I've destroyed two so far. Tried oil, Vaseline, tapping them on, and channel lock pliers. What am doing wrong here?
  • Jesse J
    scale FE enthusiast
    • 7818
    Pics? Not familiar with connectors..
    "Look good doin' it"
    See the fleet
    • Panther6834
      • Apr 2020
      • 708
      I know exactly what you mean. I tried the QS6 connectors, and, after having problems with almost every one of them, I finally gave up. I switched to RCProPlus Solderless S7 connectors (7mm vs QS6 6mm), which are not only slightly larger in diameter, but they have a higher electrical capacity. Plus, with the advantage of being solderless, they're not only easier to work with, but also reusable. The only downside - at $60 for four complete sets (4 male red, 4 female red, 4 male black, 4 female black), they're not exactly cheap. If you're interested in checking them out:
      RC Pro Plus has been at the forefront of battery connector development for years. Providing high quality, and high reliability, RCPP has... RPPREB7808STS7P8
      • 1coopgt
        • Feb 2019
        • 417
        So those connectors are solderless. What did you solder?
        • Spat
          • May 2020
          • 31
          QS6 are 6mm connectors bought through OSE. No problem soldering, just getting the plastic housing over the connectors
          • Peter A
            • 1624
            Are they the red ones? Did you try to push the connectors into the plugs? I think you have to put the wire through the connector, solder on the bullets and then pull them back into the plugs.
            • Spat
              • May 2020
              • 31
              Tried it both ways
              • 1coopgt
                • Feb 2019
                • 417
                Tried it both ways
                Did you get much solder on the outside of the barrels when soldering? If so the extra solder may be the issue.
                • Spat
                  • May 2020
                  • 31
                  First time yes, sanded it all down then cut them off and soldered a new set being more careful
                    • 4340
                    I'm not familiar with those connectors, but one of my tricks is to use a bench vise as a press, or to support the connector base from the bottom as the wire passes between the jaws and then to use a round punch and hobby hammer to tap the connector into place.
                    • Spat
                      • May 2020
                      • 31
                      Sounds like a plan! Thanks
