1/8 scale hydro brushless setup
  • U.L. HYDRO DRIVER ICE
    • Apr 2008
    • 265
    I have got a 1/8 scale carbon fiber hydro and wanting to know which motor I should use in it for brushless . I would like to achieve speeds around 60 mph or more and also how many lipo cells should I run to thanks cx
    • Apr 2008
    • 265
    Or a neu motor suggestion
    • Ub Hauled
      • 3031
      lots of people use the 1527/1.5Y, a LOT of power, specially with such light boat...
      get the strongest ESC your money will go, the Hydra 180 HV is the minimum that
      is advisable.
      10s2p with a total output mAh of 10,000 is maximum allowed by NAMBA (if you wanna race).
      Stick with the good cells... Flightpower, Thunder Power, Poliquest, PolyRc, if it's too much then
      try the Elite cells, they have definitely proven themselves
        • Apr 2008
        • 265
        thanks
        • Ub Hauled
          • 3031
          Dpost
            • Apr 2008
            • 265
            Would the 2215 neu motor work to or should I just stick with a 1527 thanks
            • Ub Hauled
              • 3031
              Some people say that the 2215 is a bit heavy for the hull, others say it's ok...
              there is a debate going on whether it is too much motor and taking away from the
              sportsmanship of the game... I think it's doable but it's not very fair since it turns into a
              "deep pocket" race. Just so ou have an idea, the oval speed record was performed with a 1521
              motor by Ken Joye... I am not sure if it still stands or not... but regardless, it was fairly recent (1 year ago or so).
                • Apr 2008
                • 265
                Thanks again because this will be my first 1/8 scale and which prop would you suggest to start out
                • Ub Hauled
                  • 3031
                  it'll depend on the motor you choose, I used a 450 on my 1/8th with the 1527
                  and I think "Eddieh" used something a bit larger, not sure of the size.
                  Are you a full size Hydro Racer ?
                    • Apr 2008
                    • 265
                    Yes I race in the unlimited lights for the u.l. 98 the page is www.ulhra.org thanks for all the info
                    • Ub Hauled
                      • 3031
                      That is awesome Charles, or should we call you "Ace"!?
                      Are you building a replica of your 1:1 boat or at least the paint job?
                        • Apr 2008
                        • 265
                        The 1/8 scale is a miss budweiser also my brother races in the same league to. But I have a couple smaller boats I'm working on as a replica of the one I race . The miss budweiser was always my favorite boat growing up. Just curious what was the record speed for the 1/8 scale. So do you think I will hit around 60mph on that setup you suggested thanks again
                        • RPC1
                          • Apr 2008
                          • 112
                          You could always try the Medusa Research 3680 1100V2SE-5 on 8s lipo
                          • Ub Hauled
                            • 3031
                            http://www.medusaproducts.com/motors...MR036080XXXX-5
                            Sorry man, I don't think that this motor is appropriate for a hull this big, it's a 36mm can even though it's a bit longer then the average XL can.
                            Charles, Ken's record can be found here:
                            I do believe that if you have your setup right you will achieve 60+mph, there are people more experienced then I in this sport and I am sure they would agree with me, but I'll let them chime in.
                            BTW, the record was set a couple of years back...
                              • Apr 2008
                              • 265
                              Should I just go with a 2215 neu or any other brand thanks cx
