Hi all, (posted this on another forum but didn't get any hits so hope here may be a bit better for this subject)
I'm completely new to the boating world and to learn the hobby i recently found a Flowmaster twin offshore cat...
From reading online reviews this model seemed to have pretty good reviews and most comments i saw was that it was actually pretty decent for its price point (although these were all from some years ago)... This model seemed to have been out of production for some time but it looks like there was production runs with different spec as most online websites say it comes with 60A ESCs whereas mine is fitted with 2x 80A Skywalker ESC to the same 2860 3300 KV motors...
I wanted to ask regarding upgrading this boat in a few stages (so i can decide to what level it makes sense to spend money on a china boat like this). I'd like to use the same hardware and running gear and not change everything (perhaps can update the flex shafts if it's recommended provided they're drop-in replacements). Please give input and any tips on the following staged upgrade options I'm considering:
1) props upgrade only
- the stock plastic props are notorious for breaking. Assuming i were to keep the stock motors and ESCs (80A 2860 3300KV) what would be the best prop options for max speed (any idea on what sort of speeds could i expect)?
*ideally any product suggestions i can buy from OSE would be great to support the forum if anyone knows particular suggestions for parts (i'm thinking props, flexshafts, couplers from OSE would be good if anyone has tips from here (or happy to look elsewhere if not available here).
2) ESC + props upgrade
- if i wanted to upgrade the ESCs to something like a 120AMP, what would be the best motor (budget-friendly options as i don't want to sink loads into this boat)?
- With 120amp ESCs would i still use the same upgraded props as option 1 or go larger (and to what size)?
- With a 120amp ESC could i run 4S or would this need a motor upgrade?
- Is it worth upgrading ESCs to 120amp with the stock motors (what benefit will i see)?
- Would any of the stage 2 upgrades require stronger flexshafts (and if so what spec)?
3) motors + ESC + props upgrade
- If i got the 120AMP ESCs what would be the fastest (but again budget-friendly) motors i can install that work with the existing mounts and set-up? I assume a ESC + motor upgrade would then mean 4S is possible and again bigger props? If i modded to this level would i need to think about strengthening the hull with more fiberglass/ epoxy inside the hull?
4) would 180amp esc be overkill for such a boat?
Frankly speaking, i'd prob only go down the motor and ESC upgrade path if i found some good used gear (i.e. someone upgrading their Probat 36 or Zonda and looking to clear their old gear). Anyone have some gear they want to sell me that would suit?
Painting tips : I'd potentially like to repaint this hull but would only be using spray cans - is the process: sand back current paint, primer, spray job (can i used tamiya TS paints or is there anything better) and then how would i get a nice high gloss finish like the current gel coat - would tamiya spray clear achieve this followed by some light sanding then buff & polishing?
here is a link to the boat but as mentioned mine has the 80amp Skywalker ESCs.
https://hobbyking.com/en_us/hobbykin...___store=en_us
I really appreciate any input!!! Thanks
