Hello to all! Well, I?ve been dying to build a twin outboard center console deep V for years. I finally bit the bullet and scored a good deal on this hull from EBay. It’s 32 inches long. I?ve built plenty of kit nitro boats but never electric or outboard. I would like some guidance as to which way to go. I?m not looking for blistering speeds. I?ve started mocking up a stringer/base system but nothing is bonded in. Here are some pics of the hull. The blue tape is where I?m thinking of cutting the hull to be able to make the inner liner. Feel free to make suggestions. Thank you!
Twin outboard center console build
Depending on how you build the inside, you are probably going to lose a lot of hull strength by cutting out that much of the deck.
I was thinking about that last night also. I changed up where my cut lines will be on the bow. I have to change the gunnels next.Originally posted by Panchothedog View PostDepending on how you build the inside, you are probably going to lose a lot of hull strength by cutting out that much of the deck.
