Prepping ML RSX380 for paint...
  • jingalls007
    • 1172
    The tub and sponsons are sanded and sealed and ready for paint. I?ll use rattlecans with a 2k clear. Do I need to sand and prime? Scuff and prime? Skip the prime and go right to paint?
    Thanks for the help doodes!
    CA80C831-24DD-4AC0-94AD-4B3D0F005A69.jpg6EC23916-2954-4328-918E-F8E1FDD539A2.jpg46A5D009-06F3-4DAF-AB39-1F29A4FA4DAF.jpg
  • Jesse J
    scale FE enthusiast
    • 7818
    Jarrett, I have been using duplicolor automotive paints with good luck.
    If it were me, I’d use the same brand primer as the paints you intend to use.
    You may get away without priming, but may not get as nice a finish.
    "Look good doin' it"
    See the fleet
    • jingalls007
      • 1172
      Thanks Jesse!
      Do you recommend scuffing the hull before primer?
      • Jesse J
        scale FE enthusiast
        • 7818
        I would use 320-400 to make sure it’s not glossy.. so yes scuff.
        See the fleet
        • MarkF
          dinogylipos.com
          • Mar 2008
          • 988
          It will take more coats of paint without primmer so I always use primmer on my wood boats. Most of my boats use fluorescence color and they work better with a white base coat so I use white primmer. But I'm sure there are plenty who will say they used every way possible and got a good paint job.
          • jingalls007
            • 1172
            I’ll be using a neon green. My primer is grey so hopefully that works ok.
            • NativePaul
              Greased Weasel
              • 2770
              It won't be OK, you need a white base if you want the neon green to look like neon green.
              • jingalls007
                • 1172
                White primer is ordered.
                Thanks guys.
