Blackjack24
  • George23
    • Nov 2020
    • 4
    Blackjack24
    Killed the motor looking to replace with the same size but is discontinued trying to figure out actual options for replacemt. I do understand I will probly have to upgrade the esc one with a built-in lvc would be nice not sure what my options are
    • 4335
    I'm pretty sure the stock motor in that boat was a 36mm 2000kv 4 pole. I don't recall the length. You'll be able to find an aftermarket equivalent to fit. I ran the DYNM3910 stock motor from a 29 V3 blackjack in mine for a while, current version of that motor is a DYNM3831. Problem is you'll need a different motor collet, and will have to tweak the motor mount for additional clearance between the motor and the end of the stuffing tub inside the hull.
    • George23
      • Nov 2020
      • 4
      How big of an esc will I need to upgrade to to allow for the bigger motor plus trying not to run it so hot already put a second water pickup on the hull
      • Jesse J
        scale FE enthusiast
        • 7241
        If it were me I’d go 3000-3500 kv, on 2-3 S with a 120 amp esc. Starting with a 440/2 maybe going up to 440/3 or 442 prop depending on temps and handling.
        "Look good doin' it"
        See the fleet
          • 4335
          Honestly, keep it simple with that hull, learn what you can, but don't throw a lot of money at it. It's limited in speed due to its size, and won't take many violent crashes because it's plastic. I think the stock esc was only 30A and barely enough for the stock boat. I ran an inexpensive 120A Hobbyking in mine. The motor alone won't really increase the amp draw much, but a bigger battery or larger prop will.
