Who still uses a RX external switch on their boats?
    I still do but it seems few still do.
    What do people use as a safety measure to prevent prop spinning on table?
    It doesn't happen to me but, I was curious if there is a trend of no external switches...
    I have seen in summer of 2019, boats powering up on work tables at boating events and it made me curious...
  • TRUCKPULL
    • 3293
    I put one on every Boat.
    One more thing to help keep the retrival people safe.
    Also when you have back to back races, you do not have to un-tape and disconnect one boat before you can connect the next boat and tape it up.
    Just have both boats ready, Turn one off and the next one on.
    Larry
    • NativePaul
      Greased Weasel
      • 2770
      Kind of, all my boats have safety loops that disrupt the battery to ESC connection and ensures that the motor can't run. As I use BECs in one form or another this also removes power to the RX.
      • T.S.Davis
        • 6266
        I haven't had one in maybe 10 years.
        Noisy person
        • RaceMechaniX
          • 3024
          I do prefer to use Rx switches in most of my boats to reduce the risk of an accidental trigger bump and a little more safety for a dead boat.
          Where possible I still prefer to run external Rx batteries as I believe they are a little safer than relying on BEC circuits.
          In boats that do not have an Rx battery, I will run the positive wire from the ESC through a switch and then connected to the receiver.
          I also run pumps in most of my boats now powered off the receiver voltage. So the switch prevents the pumps running dry on the bench before a race.
          Tyler Garrard
          NAMBA 639/IMPBA 20525
          T-Hydro @ 142.94mph former WR
            Cool. Thanks for your responses. I too use separate RX pack and switch. I am using 6.6v liIon packs with no regulator.
            On small boats <26", I do use the internal BEC sometimes for space reasons.
            I used to have a safety loop on my DF33 and sorta wish I left it in but I may put in safety loops on a couple boats in the future. Loops are the safest method imo if you can do it. My DF33 had a big 8mm plug and 8G wire.
