Motor Identification
  • Fairbarnacle
    • Sep 2020
    • 13
    I recently purchased a used BBY SS 30 Sport Hydro and am trying to figure out what motor was installed in it. The only markings are showing 2030kv. The motor can is 36.23 x 56.26mm. I plan on racing p-ltd so it looks like I'll be class legal for NAMBA but would like to know more about it.
    Screenshot from 2020-10-07 15-06-32.jpgScreenshot from 2020-10-07 15-06-57.jpg
  • pescador
    • 503
    Pretty sure thats the Aquacraft 2030kv, I think they are getting harder to find now. You should be all good to go [emoji3].
    Namba District 16
    • Panther6834
      • Apr 2020
      • 708
      I could be wrong about this (still somewhat of an FE newb)...but, if memory serves me correctly, that motor was sorta-kinda 'jointly' developed by Aquacraft, SSS (ie. TFL), & ProMarine, and should be a 6-Pole motor. What I do know is that, as far as I've been able to determine (based on internet into), the Aquacraft & SSS motors appear to have identical specs, with the only difference being the can colors - gold for Aquacraft, black for SSS.
      If correct, I don't know whether SSS/TFL "bought out" Aquacraft's 'interest' in the motor, or whether Aquacraft "handed over" all manufacturing to SSS/TFL. I've got the SSS variant installed in my CF Pursuit, also for P-Ltd, and the motor runs as smooth as can be.
      ~ More peace, love, laughter, & kindness would make the world a MUCH better place
      • Jesse J
        scale FE enthusiast
        • 7818
        Is it gold or greenish?
        "Look good doin' it"
        See the fleet
        • Fairbarnacle
          • Sep 2020
          • 13
          Gold. Looks like an aquacraft.
          • T.S.Davis
            • 6266
            Aquacraft 2030 most likely. NAMBA legal. Zero relation to the SSS motors as far as I know.
            Noisy person
              Yep, the AQ2030 motor had no relation to SSS (which broke away from TP and started in business only after that motor was introduced) nor to ProBoat. Color and ?specs? have nothing to do with motor relationships when discussing Chinese motors. They copy each other shamelessly, with many using sub-par parts and assembly to reduce their own selling price. Many spec sheets are simply wishful thinking sprinkled with unicorn dust and chinglish....
              • Panchothedog
                • Oct 2015
                • 173
                Fantastic description of Chinese quality control. Plus I learned a brand new word today "CHINGLISH". All smiles.
                • Panther6834
                  • Apr 2020
                  • 708
                  Just curious...but...is Chinglish anything like Spanglish? Lol
                    Just curious...but...is Chinglish antonio like Spanglish?....
                    Antonio say: “it is idemical”.
                    • Panther6834
                      • Apr 2020
                      • 708
                      Antonio say: ?it is idemical?.
                      Darn typos...meant 'anything', c not 'antonio'.
                        The newer PB 2000kv blue motor DYNM3831 is probably from the same factory as the Black SSS 2030kvmotor as they are almost identical.
                        • Panther6834
                          • Apr 2020
                          • 708
                          Maybe they're made in the same factory, and maybe not...but, still, two entirely different motors. Saying these two are "almost identical" is like saying the Toyota 22R & 4AGE are "almost identical", just because they were made in the same factory, and had almost-identical HP.
                          As for being "made in the same factory", I'm sure LOTS of different motors, to be sold under multiple 'brand' names, are made in the same factory. What I was attempting (incorrectly, as someone else posted, after my initial comment) to say was that I was led to believe (based on something a few others had said a while back, in a different thread) that the Aquacraft & SSS 6-pole 2030kV motors were the same, even though they might have been built in different factories. This was, again, based on what some others said, over a year ago, in a different thread (I can't recall whether it was in the OSE, or RC Groups, forum).
                          • T.S.Davis
                            • 6266
                            I've had both apart. Not the same. The earlier versions of the AQ motors were much better motors than the SSS in my opinion.
                            Another interesting thing with some of these manufacturers is that there can be variation within lots too. The gauge of the wire and even the quantity of copper can be different from batch to batch of a single brand. It's hard to get the nogin around but you can get the same kv from two motors that appear identical, are in the same can, from a single manufacturer and one could have less copper in it. The one with less copper is capable of fewer watts. Sucker will get a lot hotter on the same prop. Within spec so they send em. It's maddening. More common with less expensive motors. I suspect they're just not concerned about their reputation like Neu or even TP. TP isn't top shelf but they're performance is solid and pretty consistent. They also use higher temp wire.
                            When you're looking fer motors.....ask around about them if you can. Not all manufacturers are guilty.
                            Noisy person
                              There is no condemning of actual experience. From you Mr.Davis, I take advice as gospel 99.9% of the time.
                              Thanks for all your input!
