The struts on my Cheetah are both at an angle towards the center line of the hull. These are original 110 mm struts on an undamaged hull. The angle appears to be equal as near as I can measure. The transom mount area appears to be square with the hull. The hardware holding the mounts to the hull is ALL TIGHT. When I remove the struts to grease the ball area I am tempted to bend the two arms that hold the strut on and correct the angle. Is this a way of solving the problem? Is this a problem at all?
Has anybody found a replacement strut that is sturdier than these? Thanks for any help on this
