Set up help for 26" play mono
  • Newtonmarine
    • Feb 2013
    • 51
    hey everyone. I just picked up a 26" mono that has one side hollowed out to make it "anti turnover". My goal for the boat is just to have a play boat that I can take down to a local lake that is normally rough and mess around with. Potentially my son will hopefully want to drive it. Anyways I dont need it to be extremely fast, just to havr fun with. What motor/esc combo would you recommend? It is only 26" long. I was thinking just running it on 2s, but not sure? Thanks
    David Newton
    www.newtonmarine.com
  • NativePaul
    Greased Weasel
    • 2770
    Sounds like it may be a Mono1, they typically run a 2860 3400 ish kv, 90A+ ESC and 36mm ish low lift prop on 3s 4000-6200mAh.
    They can also be 2860 5000 ish kv 120A+ ESC, 36mm ish low lift prop, 2s 5000-8000mAh, but 3s is a bit more efficient.
