aeromarine 36 sprint cat twin drive suggestions
  • jaike5
    • 564
    how did that race run with a five boat minimum ???
    J.
    • TRUCKPULL
      • 3293
      J.
      By the third heat, two boats had dropped out.
      Larry
      • hiboatah
        • May 2011
        • 8
        tnx Larry
        I don't like choices
        Especially when the favorable choice entails a whole lot of work
        The enticing thing is...the results are logically favorable
        Amen Jay...life could be a whole lot easier but considering this is an extremely cool hobby, getting up in the morning each day looking forward to building a single would not be as purposeful as building a twin. no offense pls.
        I'm going get building - tnx guys
        btw rocketman and his cronies (Hansen Dam) inspires me to build this
        • jaike5
          • 564
          No offence taken ! Cool hobby is right on! I would rather build two boats than put double $ in one ! Raced with one in FLA. could only keep up couldn't pass him, cool boat though, and quick.
          Cheers, Jay.
          • T.S.Davis
            • 6266
            Larry's cat is disturbingly fast. Absoutelyly violently fast. I'll vouch for it. Might be the fastest heat cat I've ever seen.
            Haha....If Larry had a youngsters eye balls it would be really tough to beat.
            Noisy person
            • TRUCKPULL
              • 3293
              Thanks for the KODOO's Terry.
              Larry
              • dasboata
                • Dec 2010
                • 3972
                I am building the 36? Avenger same bottom as the sprint but more room inside going to run 4060 on 6 with some water cooled Xlx
                • dasboata
                  • Dec 2010
                  • 3972
                  • TRUCKPULL
                    • 3293
                    Chris
                    That is the same hull that I run.
                    Info on my setup in post #2.
                    Larry
                    • dasboata
                      • Dec 2010
                      • 3972
                      Originally posted by TRUCKPULL View Post
                      Chris
                      Larry
                      Larry sound like a good runner cant wait to finish it Troy cut it down a bit and built it super strong for me
                      • hiboatah
                        • May 2011
                        • 8
                        Larry, no need to be humble about all those performance remarks. In picture 3, looks like she's haulin the stuff real good!
                        Terry, interesting how life serves us...when we are intelligent enough to use the resources, we are handicapped to do so...
                        Thank you for posting Chris. Looks like you're on your way. Interesting...locate the stinger location...fabricate your flex housing and motor mount angle simultaneously to create the flex housing route (usually w/slight bend)
                        I'll be getting the contour gauge indicator (that Ray recommended) to create a reverse contour of my sponson. I'm thinking this will be the easiest way to assemble a starting cardboard template for my motor mount.
                        Pray for me boaters, this is what I'm working with. Will be using 36mm motors as that's all that will be fitting between the deck and tunnel.IMG_1189.jpgIMG_1185.jpgIMG_1187.jpg
                        • dasboata
                          • Dec 2010
                          • 3972
                          delete
