Plettenberg motors and compatible ESC's?
  • eXoNerated
    • Jun 2020
    • 233
    #61
    And here are all the castle drives that support it.....
    I wish I knew more about the castle software. I bet there is a way to spoof the discontinued hydra ice drives. Make it appear to the software as one from this list. U need at least fw 4.25
    • eXoNerated
      • Jun 2020
      • 233
      #62
      • NativePaul
        Greased Weasel
        • 2770
        #63
        Originally posted by eXoNerated View Post
        I know that Paul, you didn't read clearly what I said. Because they are not making them anymore does not mean people don't still have them, and they can still be addressed through firmware revision just like current inverters they do sell modified for marine use. I have 2 HYDRA HV ICE HV200 v2's and they've never been returned. I have them both right now working fine in addition to the 2 APD
        Get over yourself and stop trying to imagine what people are thinking Hubert, it clearly isn't working out for you. I did read what you said, I didn't even disagree with it, I know people still have and use Hydras, I still use one myself, as I told you in your GPS/Datalogger thread. I just don't believe Castle will release any more Hydra firmware now that they are out of the market.
        • eXoNerated
          • Jun 2020
          • 233
          #64
          "Castle stopped making boat specific ESCs some time back, too high a return rate." Verbatim
          Do u see u said nothing about firmware? So don't get mad when you post doesn't make sense. The firmware idea was in your mind but you didn't say it so I cant read your mind. That's what I saw written and b
          ecause I tell you in reply I know castle doesn't marine controllers any more based on that.Simply answers to your statement above. I have no idea what you are talking about "on top of myself" but anyway. Looks like you on top of me for no reason. They could support a firmware upgrade if they chose since they still support the drive as you can go and switch between firmware currently. If the hardware is the same all they have to do is change the header.
          Please allow me free passage of information to the op. Please allow him a moment to process the information that's posted for his benefit.
          007
          I threw this small thrust stand to test the motors with a prop. Its simply a pair of drawer slides a digital fish scale and wood. The servo mounted beneath is actually used as a reactionary torque sensor for the small motors like 22 series drone motors. You have more pm's One the shop is done Ill really make this in metal with a TEDS capable load cell and reactionary torque sensor. This work good enough to tell you the grams of thrust per watt. A measure of efficiency in the prop and machine. If one had a MSH BRAIN and a castle they could see what happening here in real time.
          Regards
          Hubert
          • eXoNerated
            • Jun 2020
            • 233
            #65
            @jingall007
            Whats kind of logging does the SEAL have? Have you ever viewed it?
            • jaike5
              • 564
              #66
              how about focusing on getting shc. 40/160 back to market instead of a key stroke war.
              • jingalls007
                • 1172
                #67
                Exonerated- these forums are supposed to be fun and educational not toxic and caustic. If you can?t play nice then please refrain from anymore posts in this thread or elsewhere.
                  #68
                  Guys, if you cannot maintain forum decorum you can’t post here. Stop acting like children.
                  • HTVboats
                    • Jun 2011
                    • 936
                    #69
                    You must want a response since you mention my name in a motor thread I have not participated in. Anyway as for my props which you seem interested in my box has props from Mark Sholund, Andy Brown, Jerry Crowther. Alex Dr Props and I have done about 60% of the props I use. I have set documented world records with all of the above. Chris (Dashbota) has a great reputation (unlike yourself) and has helped many boaters with his prop work. I haven't used his services as I don't run gas anymore and the sources I have do what I need. I have answered your inquiry so no need to respond but you will of course, as Humble Hugh has to get the last word in. I'll throw you a softball so you can rant on. Your knowledge and education are wasted here as your presentation and people skills don't inspire anyone. Tell us more about actual BOATING accomplishments? Have you ever competed off a keyboard?
                    Mic
                    Mic Halbrehder
                    IMPBA 8656
                    NAMBA 1414
                    • Diegoboy
                      • Mar 2007
                      • 7443
                      #70
                      Clearly he cannot. I opted for the best solution for all.
                      • dasboata
                        • Dec 2010
                        • 3972
                        #71
                        edit edit !
                        • jingalls007
                          • 1172
                          #72
                          Thank you sir.
                          • Doug Smock
                            • 5359
                            #73
                            Thanks Danny!
                            MODEL BOAT RACER
                            IMPBA President
                            IMPBA 19887L CD
                            NAMBA 1169
                            • Dr. Jet
                              • 1759
                              #74
                              Me too! Thanks!!
                              A nation of sheep breeds a government of wolves
                              • RaceMechaniX
                                • 3024
                                #75
                                Thanks from me too.
                                Tyler Garrard
                                NAMBA 639/IMPBA 20525
                                T-Hydro @ 142.94mph former WR
